I have a LG DLP, it comes on then suddenly the bulb goes out and the red light blinks. I know the bulb is still good. I need to find out if the fan is working or is dirty. How???
  • 435 Answers
Sounds like a power supply failure. Protection circuit is trying to prevent further damage to the set.
You will need a tech who can take voltage measurements in order to find out what is going on inside.
If the set is still under a warranty program contact them right away. Otherwise you will need an experienced expert who can troubleshoot it.
Thanks
Posted on Sep 13, 2008
    Genius:
  • 2,035 Answers
Remove the lamp and reset lamp back and then power on the tv ,please follow the instruction in the link to remove the lamp:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=2883
Please let me know how many times the red light blinks...
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
LG DLP TV temp problem
A temp problem? First check all the fans and make sure they are free from debris or check to see if they are spinning.
Dec 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
Lg tv will not turn on it is a micro projection 55 inch hd dlp xd hit power a hundred times and it will eventually turn on but this is what it does it will blink yellow the bulb will light up screen will...
Have you actually replaced the lamp first? A weakened lamp will often cause random shutdown or troubles during initial firing of the lamp. The LG televisions will be just the bulb itself not the complete lamp assembly. It's not hard to replace the bulb as long as you first allow the TV to cool down for a minimum of an hour. Then you will want to handle the lamp with latex gloves on to avoid getting oils from your skin on the bulb. You can find your bulb replacement at http://www.partstore.com
Nov 12, 2009 | Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
TV keeps shutting down
Sounds like it may be a bad ballast
Mar 24, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
