Question about Sony KP-53HS20 TV
Sony Hi-Scan 1080i 52" projection TV colors won't converge
Red is projecting an image up and to the right of the main picture making the TV look like a 3-D movie without 3-D glasses. The Auto convergence will not align the colors. Can this be adjusted manually and if so, how?
  • Anonymous Feb 12, 2009
    picture looks 3. Model KP-53HS30. Flash focus doesnt help
    Novelist:
    Champion:
  • 203 Answers
No you will need to repace compents. Do you know how to solder and use a meter? If so I can assist you with the repair. If not you will need a repairman, he will cost you about $300-$500 for the fix.
Tim Nolan
Posted on Sep 13, 2008
My tv image is oval it has a line of red, blue, green on top of screen
The tv have a problems known as a convergence problems it,dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D look like pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA HD52W56 52" Rear Projection HDTV
52" projection, colors have seperated making images in triplicate
Go to the main menu on your TV and scroll down to picture then press select. Then scroll down to convergence and press select again. Next follow the on screen instruction on how to perform a static convergence on your set. If this doesnt solve your problems check all capacitors in the convergence section of your TV. If problems persist replace both convergence chips.
Aug 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My projection tv is showing a triple image and i don't know how to fix it?
Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
I own a 51" sony rear scan projection tv
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture with red 3-D effect
IC8001, STK392-560 seems defective, its convergence output IC.
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KP-53HS20 TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
