Home | Sendo | X Handheld | INFRA RED LIGHT IS ALW...
Sendo X Handheld
Problem for Sendo X Handheld
INFRA RED LIGHT IS ALWAYS ON
By 4BA1 on May 18, 2006
The light is on always, even when the infrared is deactivated and also when the set is charging at off state but the phone is not hot.
Same Problem
Feb 16, 2009
-   How can I remove lock code from my Sendo X -   Guest
Solution #1
posted on May 22, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3605 votes
If it doesn't heat, and doesn't drain the battery, then I don't see how it can really be on... it takes a lot of power.
If you don't have a warranty on it, or a service plan with your provider, try reseting it. just save everything you don't want to loose before.
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature.
Series 60 reset
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
1. Switch off the phone.
2. Hold down the '5' key, and with this held in, turn the phone on with the power button
3. Wait until a green tick appears over the right softkey, then release the '5'
4. Follow the prompt to reset the phone
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations, and it's advised that the handset has a reasonable amount of battery charge before performing a format/reset.
Was this helpful?
Yes
No
Solution #2
posted on Sep 20, 2007
Not Helpful)
ikp4success
Rank: Apprentice
Rating: 55%, 1 votes
i have already reset my phone by dialling *#7370# my infrared does not still work what should i do.
Was this helpful?
Yes
No
Popular Solutions for Sendo X Handheld
Questions and Unsolved Problems for Sendo X Handheld
Do you recommend Sendo X Handheld?
Answer
Answer
my sendox phones shows system error at times and i can"t download games,software.it has... (More)
Answer
Please my sendo x panel is always hot and the battrey did not last any time i insert it into the... (More)
Answer
Please how do i disconnect my infra-red on my sendo x
Answer
what can i do to uprgade tha ram in my fone
Answer
actually is calling and receiving a call but i can't anyhting on it than  that,and is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sendo X Handheld:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
