My rca #d52w14 will not turn on. What can I do... There is a green light and it does come on for about 8sec. then goes off again and it does it three times in a row, but the tv will not stay on.
  • vgilbert5 Sep 13, 2008
    My tv is actually a HD52W59. I've turned the computer off (over night) and it's doing the same thing.
    I'm a lady...Valerie :)
    Novelist:
    Champion:
  • 203 Answers
This is a difficult set to troubleshoot. Do you know how to use a meter and solder? If so we might be able to fix this one at compoent level. You can have many things wrong at this time. The flyback transformer is common to go bad, the trippler is common to go bad, and the signal board is common to go bad. We need to check the collector of the hoizontal output for a short and if its not shorted we need to check it for voltage at turn on. Let me knwo if you can do this and I will show you where this is located if you dont know.
Tim Nolan
Posted on Sep 13, 2008
    Genius:
  • 1,239 Answers
Hi you replace fuses and the flyback transformer
Does the power light ever light on this set?
    President:
  • 1,952 Answers
    Master:
  • 763 Answers
Sir, after all the suggestions here and still the problem persist you should send it back to the place where you bought it for a repair service. if this item is cover with warranty that would be good. hope that helps!
CHARCOIS
  • 19,396 Answers
Try first disconnecting the power cord for one hour or so.
If after restarting you still get the problem, it means that there is a problem with one of the internal components.
I can try tracking the error code and see what the problem is.
  • Ginko
    Ginko Sep 13, 2008
    3 flashes is code 33, convergence error.
    That is a convergence problem, to fix it it is necessary checking the soldering at the yokes, test
    horizontal convergence IC, test a couple of capacitors and resistors on
    convergence circuit, and sometimes the technician may have to replace the whole convergence pcb inside.
    The wole job starts from $80 and usually costs over $200, depending on what parts must be replaced.
    To get service you can call the number listed on the owner manual, or look for support on RCA.com website.
    If you contact RCA you can also ask them if they provide guaranty extension. This is usually cheaper than the repair cost, and gives you one or two years additional guaranty cover.
    Let me also know if there is any additional error message on display.
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
My tv is a RCA D52W14 the green power light comes on then goes off the television takes a long time to turn on
Bad capacitors on the deflection board CP150, CP120 and CP114 very common for that model. You can get the repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52w14 light on power button blanks three times then goes off
In the middle of the deflection board. The one on the fall left from the back.There is a heatsink with three sides to it. Inside it there is a capacitor . If the top is swollen replace it. I think it is c150.
Sep 19, 2009 | RCA Televison & Video
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
May 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
