My dishwasher has stopped working.it sounds as though it tries to empty at the begining of the cycle. but then it is not filling with water. i have checked the water supply this is ok and electric supply is fine too.
the only thing i can add when the fault was discovered there appeared to be a small amount of oily water on the floor maybe from underneath.
i would be greatfull for any advice you could supply
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
I have ideset IDL 530 - 1st 2 lights are on and flashing- will not reset and water in bottom of...
(More)
I have ideset IDL 530 - 1st 2 lights are on and flashing- will not reset and water in bottom of washer - what is causing this?
Have a cabinet unit with a door fitted with large hinges. Trying to mount the fridge freezer inside...
(More)
Have a cabinet unit with a door fitted with large hinges. Trying to mount the fridge freezer inside results in side of appliance being scraped by the hinges - they are too big. Rang for instructions and pathetic photocopy arrived, so dark we can hardly see the picture and the instructions are in Italian! We have worked out how the appliance doors fit to the cabinet doors at the opening edge but cannot fathom how the cabinet hinge edge fits either to the cabinet or to the door of the appliance. Any clues would be very gratefully received! Jane
