After the summer, my gas fireplace isn't working. It seems like there's no gas coming through.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Call the local gas company to checkout your system for free!
Posted on Sep 13, 2008
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
How do we fix a remote control for a Direct Vent Fireplace?
check to see if you have a resettable dip swith in the venting system, if you do have one, press it once, it should then come on. also make sure the gas valve is in the on position and not just in the pilot position,. Also after being off all summer season, sometimes a slitgh tap on the gas control is all it needs to dislodge the magnetic pilot plunger.
Oct 01, 2016 | Heating & Cooling
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
2003 mini cooper AC compressor doesn't run
indicates a low gas problem
have it properly diagnosed by an ac specialist shop
Oct 30, 2017 | Mini Cooper Cars & Trucks
I have the honeywell round thermostat #, CT87K. I am trying to wire it up to controla gas fireplace. I have two wires coming from the fireplace I have tried every combination of wires. it will turn the...
That Thermostat will not work on a gas fireplace. The voltage is all wrong. You need a thermostat that will work on millivolts generated by the thermopile on the pilot assembly of the fireplace burner. It will only turn on, because you opened the circuit. It will not turn it off automatically or at all, for that matter.
Better yet, why don't you purchase a Wireless Remote Control that has a thermostat built-in. It's a multifunction remote that will work up to 25 feet from the fireplace and comes with a wall hanger. The SkyTech # 3301TH, should work well for you. http://www.skytechsystem.com/
Feb 17, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I have a black soot on all my walls through the whole house especially the exterior walls. I believe it is caused by my propane fireplace. Im not sure if it is not ventilating properly or what the problem...
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
  • Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
  • Misplaced logs that impinge the main burner flames.
  • Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
  • Burning scented candles while burning the fireplace.
  • Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
  • Have the fireplace cleaned and serviced.
  • Check your Owners Manual concerning the proper placement of each log,
  • Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
  • Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
  • Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you.
Please let me know at americanhearthandhome1@yahoo.com
Thanks ... Rich
Feb 16, 2011 | Heating & Cooling
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
Jan 07, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
I can not lit the pilot
it sounds like air in the pilot tube its a very small hole in the pilot and takes ages to come through undo
the pilot tube at the gas valve and see if you have gas coming while depressing the the knob
Oct 06, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Montego gas fireplace
There is a product that I use when servicing gas fireplaces that works pretty good. Google search "Rutland White Off". In a lot of cases it takes just about everything off and the glass looks brand new. If it went to long without being cleaned, it could be permanently baked into the glass. As far as removing the glass, every manufacturer uses there own style of clip. Check around the bottom of the fireplace where the controls are for a latch or possibly screws that are holding it in place, sorry, without looking at it, it's pretty hard to answer that part of your question
Jan 11, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
