Question about Cyberhome CH-LDV1010A Portable DVD Player
Dvd player 1010a portable
When you turn on the power i get no picture just sound , i can hook up the dvd player to the tv and get a picture but not when you run the dvd player it just gives me sound ?
  • vicand0303 Dec 08, 2008
    I turn on the dvd player and no picture only only sound but i get picture when is connect it to a tv
    President:
  • 3,130 Answers
Sorry nto tell ya that something must have happened to the lcd screen or display. Has it been dropped ?? If you hold it up to a light do you see an image but no brightness as could also be a backlight problem . My advice would be to see if theres any type of warrantee on the unit cause from experience this repair PROBably is'ent gonna be cheap and I say this cause most repair centers wont even look at something like this for under 30 to 50 bucks. Good Luck
Posted on May 18, 2006
Cyberhome 1010A won't read disc
Clean the laser with a q tip and rubbing alcohol. That usually works with lasers that don't read. If this doesn't work ( be sure to let the alcohol dry and don't leave streaks) then I would either assume the laser isn't getting enough power or the laser is actually burned out.
Nov 01, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
My cyberhome CH-LDV-1010A dvd player does not go pass reading.
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Cyberhome CH-LDV1010A Portable DVD Player
CyberHome Dvd Player, Model: CH-LDV 1010A
I have two of these batteriers if you still need them. I'd rather not throw them away if they could be put to use. You pay shipping they are yours for free.
Frank
Oct 12, 2008 | Cyberhome CH-LDV1010A Portable DVD Player
PORTABLE DVE PLAYER MODEL PDV-705
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up. This button is about the size of a pin on most DVD Players4.gif, and is located very close to the screen on either side.
Jan 10, 2008 | Durabrand PDV-705 Portable DVD Player
Portable DVD Player
make sure your player is set to the video output, and not set for internal use.
Oct 11, 2007 | kawasaki PVS1965 Portable DVD Player
Phillip PET710 Portable DVD Player
The back light of the monitor might be defective. or the drive signal might not be getting to the screen you will need a schematic, multimeter, and an oscilloscope to troubleshoot this issue. This is how you will have to go about this using the schematic locate the screen test points measure the voltages with the multimeter and look at the signals with the oscilloscope. this will lead to you finding the exact problem.
Jul 25, 2007 | Philips PET710 Portable DVD Player
No image
Your unit has a composite output. Hook a standard TV up to this connection and try it. If you have a picture your display on the portable unit is bad. Sounds like you lost the backlight. You would need to have a tech look at this to fix it. Good luck.
Jun 19, 2006 | Samsung DVD-L70 Portable DVD Player
Cyberhome CH-LDV1010A Portable DVD Player Logo
113 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
