Question about Panasonic Microwave Ovens
Panasonic microwave model # NN-6543. LED works (timer), counts down the seconds, but turntable and oven does not work.
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 13, 2008
Panasonic microwave oven nn h965wfx
either your magnatron is bad or hopely it could be your high or low heat sensor
Oct 13, 2013 | Microwave Ovens
NN-SD6968 set the timer, press start, timer counts down, microwave doesn't run?
I just developed this problem with my panasonic inverter microwave...does anybody know about this problem?
Apr 12, 2011 | Panasonic Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Panasonic - NN-T993SF 1350 watts microwave
Sorry this is something you wont fix at home I couldent even do this one.This is a nice unit depending on the cost this one I think is worth the repair bill , Good luck DFD please rate me TK U
Apr 12, 2009 | Panasonic NN-T993SF Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 18, 2008 | Panasonic NN-S763BF Microwave Oven
Glass turntable
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yysrsj
Sep 02, 2008 | Panasonic NN-S962 Microwave Oven
Microwave Ovens Logo
145 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
