Question about RCA D61W130 61" Rear Projection Television
RCA SECNIUM D61W130 rear hd projection tv the dvi port willnot work
I purchased a RCA SCENIUM HD rear projection tv 5years ago. The video equip didnot have dvi outputs. so disregarded the inputs & used the component in's. Now with the HD dvd players & blue ray player & HDMI outputs my DVI to HDMI cable willnot send any picture to my tv. What do i do.
  • Anonymous Dec 28, 2008
    i have the rca 65inch rear projection tv that was suppose to be hd it has a dvi input but no hd receiver... I need to buy some sort of receiver
  • Anonymous Feb 03, 2009
    I need to buy a switch for my tv the on off button broke pushed into tv rca d16w130
I have a Rca scenium tv ...trying to connect to my hd reciver and can not get a picture ...tried hdmi cord ..adapter ..dvi cord ..and nothing at all
Easy to understand, hooking up RCA, HDMI, and othe ...
? 5:54
Jul 10, 2012 - Uploaded by kevintalkstech
A very easy to understand tutorial about what RCA, HDMI, coaxial and ... +kevintalkstech I am trying to learn ...
How To Connect: Tv + Component With Dvi Or Hdmi - Rca ... > ... > User manual
RCA SCENIUM HDTV With DLP Technology High-Definition Television ... To connectyour TV to a component with a DVI jack, use an HDMI cable and an ... Note: You canset up the TV to automatically tune to the correct Video Input Channel. .... call me at 318-578-5198 I need help as soon as possible trying to get my tv to ...
Support - RCA Television
Dec 27, 2015 | RCA Televison & Video
How do i get a full picture on my secnium hd tv?
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
RCA Scenium d61w130 turns off then on
I installed a small cooling fan in the back ot the TV. It was overheating. Fixed the problem.
Nov 22, 2008 | RCA D61W130 61" Rear Projection Television
RCA D61W130 61" Rear Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
