Question about Turbo Air TSR-49SD Stainless Steel Commercial Refrigerator
Turbo Air TSR-49SD
Refrigerator keep freezing up
2 Suggested Answers
  • 1230 Answers
SOURCE: Cannot control temp, freezing everything Turbo
http://turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
check out this manual and see if your answer is there.
Posted on Jan 15, 2011
Doors do not self shut. Stays open a little bit. Can the doors be adjusted or do springs have to be replaced?
there are no springs . check to see if it is level or just slightly off lower at the back helps close the door
May 14, 2016 | Turbo Air TSR-49SD Stainless Steel...
Door lock for Turbo AIR
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Jul 21, 2013 | Turbo Air Reach-In Refrigerator- 3...
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
orders@coolergaskets.com
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
What type values is on this unit to be able to recharge the system with freon.
I'm not quite sure what you mean by values, but if your asking the specs on the machine I can help you there. TSF-49SD R-404A OD 0.12598X ID 0.07874X
[9A0 L 90.55 + (B) 174.21]
600 21.164 AJA2425ZXA 8.7 0.0 263.2 TSF-49SD R-404A (A) OD 0.12598 x ID 0.07874 x L 90.55 + (B) OD 0.11024 xID 0.06299 x L 118.11 580 20.459 CAJ2432Z 10.5 12.8 266.0tsr-sd_spec.jpg
Apr 30, 2012 | Turbo Air TSR-49SD Stainless Steel...
I have a commercial freezer and I just replaced the gasket. Its the exact fit for this model and didnt have any problems installing it. When I close the door it wont stay shut in other words the gasket...
this is happening because of the new gaskets, what you do is lay something against the door or doors overnight and tomorrow they will be great. hopw this helps.
Feb 23, 2011 | Turbo Air TSR-49SD Stainless Steel...
I have an electrical burn smell inside the 49sd, all seems to be working... just the smell that is stronger inside.
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
This is the web site for your manual for your unit. I've had some situations where some rubber type insulation has melted but I've not experienced any problem other than it makes a mess. Hope this helps.
Feb 26, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
I want to know the wire connection to compressor
MOst common are left to right start,common .run. Russ
Jul 19, 2009 | Turbo Air TSR-49SD Stainless Steel...
Looking for the white plastic clips that shelf hangs on.
Give Rick a call at Restaurant Parts and More. Turbo Air also makes Master-Bilt. Rick can probably get what you need. Just have the model and serial. He's good at this stuff. 1-888-814-1110.
Mar 21, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Turbo Air TSR-49SD Stainless Steel Commercial Refrigerator Logo
48 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
