FixYa.com
Tags:
Panasonic Shelf System  Shelf System
Speakers (by 3 users)
posted by villmow on May 18, 2006
When i listen to music i can hear a cracking noise from the subwoofer and i was wondering if the was a simple way to fix it or if i should take it to a professional.
Comment by villmow, posted on May 19, 2006
Well when its at a certain volume then i hear it. its kinda like a buzzing noise, but everyone at my school says that its "cracking" and a friend of mine has the exact same problem with his too. ive looked at the speaker and it has no defects with it, its just that noise that it makes.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ajrosethedj, posted on Jun 23, 2008
I have the same problem with my JVC speakers, a "buzzing" sound or what have you if the volume goes beyond middle (9 or so on my system).
Comment by stephen333, posted on May 26, 2008
subwoofer makes a cracking nosie when the volume increase and sounds bad
Best Solution
posted on May 18, 2006
Helpful (85)
techman
Rank:Guru Guru
Rating: 87%, 6657 votes
Im not sure as to your complaint?? Is it like a grumble? or a type of vibration?? if its only present when the low frequency is present then i woud say that you had a bad suround on your low frq type driver?? if this is not the case then i would look into a parimetric eq as this couls solve your mproblems.
Comment by techman, posted on May 19, 2006
OK now that youve explained it a bit better its a componet thats starting to go bad as alot of solid state devices will do just before the go out they will start making noise like static type noises. The only thing you can doif your a technician is when this unit starts to do this noise spray a small amount of freeze spray on the suspected componet. Now it your not a tech there really isent much you can do as your gonna need the proper equipment to service these units but these systems have no user serviceable parts inside so my advice would be for you to take this unit into a repair shop for an estimate. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Nightdiver
Rank:Guru Guru
Rating: 88%, 146 votes
It sounds to me like a ground fault. Try a ground reducer (you can get one at any hardware store, or radio shack for about 1 dollar) If it fixes it, get a good power conditioner (monster cable has a good one) if it is still there, then I would take it to a pro.
Solution #3
posted on Jun 24, 2008
Not Rated (0)
jonsingh12
Rank:Master Master
Rating: 81%, 8 votes
Yep try plugging it into a separate wall socket don't use extension cords or a power bar.
Solution #4
posted on Dec 08, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yea i think what you are describing is a pinging/ringing noise. Attach new speakers like Bose to the system it goes away. Or just muffle the top tweeter with some kind of fabric between the grille and tweeter. It removes the pinging noise and the sound is much cleaner!
Solution #5
posted on Dec 04, 2007
Not Rated (0)
crashandburn
Rating: 0%, 0 votes
I literally fried my CD player of this system and have the Sub woofer and speakers that are siiting around, you pay the shipping and I will send them to you. Karl
Solution #6
posted on Apr 15, 2007
Not Rated (0)
djdave
Rating: 100%, 1 votes
In regards to your speakers "cracking", It is an internal problem. It will soon say "protect" on the display if you keep using it and after some time it will shut off by itself. I had the same problem with my system and I called them and they said it is a bad resister. It is not an easy fix and you will have to send it in to get fixed.
This Problem Also Relates To: GPX KCCD6316DT Shelf System Jensen JMC-300 CD Shelf System GPX HMM4514DT Shelf System Kenwood HM-381MD Shelf System Memorex Nostalgia 4-way Stereo Shelf System Panasonic SC-VK31 220 Volt 5-VCD/CD Changer Shelf System Rio EX1000 CD Shelf System
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
Sony Mini Hi-Fi Component...
I have a Sony Mini Hi-Fi... Answer This...
Audio Shelf Systems
No sound at maximum volume
"my sharp portable... Answer This...
Audio Shelf Systems
Fisher MC720 with a Matsushia...
What size electrolytic is... Answer This...
Audio Shelf Systems
Manaul or how to set the preset...
rca rp9547b i tried to find a... Answer This...
Panasonic Shelf System (SC-AK630K) Shelf...
five year old Hitachi 51GWX20B
Crackling sounds coming from... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
