Question about LG Cell Phones
Car kit mode is on and I wanted to know to take it off.
  • cpatillo Oct 13, 2008
    Car kit mode is on. Alltel basically said phone is terminal. Can it be taken off, can still text.
I just called LG and they said that when the CAR KIT mode comes on it means that it's a warning that the speaker is not working. There is no way to take it off (from what the guy at LG said). My phone went into CAR KIT mode and I think it might have to do that it got wet or something. (my daughter might have had it in her mouth!) Just an FYI.
Posted on Sep 23, 2008
How to reset the bizhub 20 printer fuser counter ?
Press the [Menu], [Start] ,and [up arrow ] button four times quickly in this order to make the machine enter the maintenance mode.
The machine beeps for approx. one second and displays " " on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the buttons.
Press the [8] and [8] keys in this order in the initial stage of the maintenance mode.
(2) The LCD shows the "Reset Laser Unit".
(3) Press the [ ] or [ ] button to select the item you want to reset. The LCD shows.
"Reset-Laser Unit"
"Reset PF-KIT T2"
"Reset PF-KIT T1"
"Reset PF-KIT MP"
"Reset-Fuser Unit"
(4) Press the [OK] or [Start] button, then " *** OK?" will appear on the LCD.
(5) OK: Press the [Start] button to reset the counter of the selected part and returns the
operating procedure (2) mode.
NG: Press the [ ] button to return the operating procedure (2) mode. Then select again
the part which you want to reset by using [ ] button or [ ] button.
Feb 21, 2018 | Konica Minolta bizhub Office Equipment &...
How do I put the speaker car kit into pairing mode as it is not showing on my blackberry when I search devices?
If it has never been paired to another device before, just by turning it on (i.e. pressing and releasing the microphone shaft), it will enter the pairing mode, denoted by the indicator light flashing alternately in red and blue, right away. In case it has been paired before, or, rather, it refuses to enter that mode automatically, you must force it into that mode, by pressing and holding the accept button whist turning it on. Anyway, once in pairing mode, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Feb 22, 2011 | Blueant Supertooth Light Bluetooth Speaker...
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Also this can happen due to shortening of the 2 power pins at the bottom. Try using an alluminium piece cone shaped and toggle the pins. They will come out. Car Kit mode comes sometimes due to moisture in the power pins, shortening it.
Sep 18, 2009 | LG VX3400 Cellular Phone
Protective mode how do i fix it
sounds like you will have to get the audio ics replaced. it would be better for you to take it to someone with the tools to repair it. unless you have a solder kit handy..:)
Jul 01, 2009 | JVC Electronics - Others
Same problem as this person.
Hello
Im sorry to hear about your problem.
If this problem happened directly after getting water on your phone then it could have been a result of shorting out and putting the phone in car kit mode (the mode for when you are using it along with a car kit) . If this is the case then your phone can't be fixed.
If the problem did not appear after the water damage then you may want to refer to the manual to find instructions on switching the phone off of cat kit mode.
Post back if you have any further questions. Thank you for choosing Fixya!
Jun 23, 2009 | LG VX8300 Cellular Phone
Can the lightsensor be adjusted and how
hi,it is a factory set-up,if you want,you may ask your dealer a kit for daylight driving mode,some country require this system,ty
Mar 25, 2009 | 2006 Mercedes-Benz ML-Class
Car kit mode
Feb 17, 2008 | LG VX8300 Cellular Phone
Car kit
You don't mentioned your cell type and model. You will get the solution definetly but before that I have to know that.
Jan 08, 2008 | Cell Phones
Cell Phones Logo
410 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
