Question about Kitchen Ranges
After self cleaning cycle, the F1 fault code appeared on the clock display. I cannot use the oven anymore. The top burners are working fine. Any suggestions would be greatly appreciated.
  • steberg Apr 08, 2009
    I have a Jenn air jgr8750adw range. After using the self clean feature, oven quit working and now have F1 code that won't clear. Also had a F9 code prior to the F1. Replaced the control panel still have the same problem. Could this be caused by the door lock motor? Nothing much else to go wrong on these units that I can see.
    Thanks
    Mark
    Sergeant:
  • 409 Answers
Can you tell me the brand name and model # off your stove?
Posted on Sep 13, 2008
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Oven shut down in mid use and locked the door. Display said it was on self clean and then switched to error code F1. We have tried unplugging, cooling, cancelling and timing down the clean cycle. This...
f1 error is generally a fault within the electronic control/clock assembly. i wouldnt want to dump the unit just yet.get the model number and look up the control probably $200 or less.
Nov 11, 2008 | Frigidaire FEF365AS Electric Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
F1 Error code
i just had this same issues happen after running the self clean cycle. f1 error, fan would come on, fan would turn off. its not the control board, its the temperature probe. I picked up the part for 40 bucks and put it in myself. plugged the stove back in and it was good to go. the old temperature probe's wires melted during self clean. note to self: clean you over the old fashion way with some elbow grease.
Mar 30, 2007 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
181 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
