Question about JVC AV-65WP74 Rear Projection Television
Convergence all over the place
I woud really appreciat eyou help opn this one. Was watching my tv this afternoon, and all was good but after dinner, when I turned it on the picture had the green sagging in the middle. I went ot the convergence, the green grid was sigging in the top middle and adjusting the red and green did not do anything. Any ideas??
  • tilleigh Dec 27, 2008
    same problem. when i turn the tv on and off several times it eventually comes on.
    Genius:
  • 2,920 Answers
Youll have to have a professional look at it
Posted on Nov 05, 2008
When was my Model 94-32 winchester spl serial #2077677 made?
January of 1955. A good year. I remember it fondly. The first McDonald's opened that year....Coke was first sold in the can....we were all eating tv dinners watching the Mickey Mouse Club in black and white. The world was a much nicer place back then.
Jan 09, 2016 | Winchester Optics
I have a Husqvarna 345 with a 18" bar. I worked
This machine has a geared side adjust tensinor, i woud say the gear system may have striped, remove the clutch and drum, remove the allen screw securing the silver bar protector plate, the adjuster will now just lift away complete, check its function, replace if required, check the oiler is working, hold the saw over some cardboard, rev the engine and check to see if there is a good oil spray onto the card.
Jan 13, 2011 | Husqvarna Chain Saw with 18" Bar
BLURRY PICTURE I need to adjust the convergence board, HOW?if I need to repair the board with a repair kit does these kit work?how can I access this board,I have electronic as well as electric experience...
If you are able to do this, the switches woud be in the back of tv under the panel. Some tv's like most newer tv's are not adjustable except under main menu for color, tint, contrast and that is it.
This is when the convergance board needs to be replaced.
Aug 01, 2009 | Televison & Video
Hi!! This is in regards to my Panasonic pt-47wx53g
There is a convergence repair kit available for your model which contains both Convergence ICs and the six feed resistors the kit also comes with free step by step with detailed pictures that explain and show how to do the repair. Heres the link to the Kit for the PT47WX53G panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 25, 2009 | Cameras
Samsung 65 in Mod HCN653w Picture Distortion
Do you have this problem on all inputs to the TV (Tuner,Video, Component, S-Video, etc...)? or just one? And does it affect the TV menu when it's brought up on the screen or no?
C-Dog
Feb 10, 2008 | Samsung HCN653W 65" Rear Projection...
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Convergence Problem?
The convergence IC most likly shorted, and burnt out the b+ feed resistor. There are two IC's inside this set to control the green red and blue convergence. They are most likly STK 392-###. The ### is another set of numbers that change depending on the model of the set. They each have three amps inside each one. You really should have both of the IC's replace with only original parts, as sub parts do not hold up and will not last as long as they should. Both IC's are soldered into place and if you decide to do this yourself, please be aware of the extemly high voltage inside of these puppys. there really are no user replaceable parts inside these sets unless you have solid state repair experience. Not only will yopu need the proper IC's, but you will have to find out what was burning. my best advice, Play it safe and call in a trained tech to assist you with this repair. The price should run someware between 300 to 450.00 to repair. Good Luck Please do not forget to rate this thread.
Dec 07, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Problems with green convergence
Very common problem John with projection sets. They have High powered audio amps inside the sets to control the red,green, and blue convergence for the color alighnment on the screen. These amps blow out and should be replace all at one time. There are also resistors that can go out at the same time and your gonna have to have these replace also if they have any discoloration to them. This is not a job for the novice to attempt, as there are HI Voltage safety issues involved, and should be done by a trained tech. This repair should run you anywhere from $250.00 all the way up to $400.00 bucks, depending on where you live and who you get to repair the set. It's always better, in my opiniuon to call a factory authourized repair place as they should have all the service data and most parts for your set. Good Luck
Jul 23, 2006 | Panasonic PT-53TW53 53" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
66 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
