Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Card lock My camera showed "Card Locked". I switched the little "slide" on the sidee of the card and it did not fix the problem. I bought a new card and the problem still is here.
  • Canon Master
  • 6,487 Answers
If you already tried a different card and still have the same problem ,try upgrading your camera's firmware because this problem is related with the software of the camera alreaady...
Hope that helps........
Posted on Sep 13, 2008
    Master:
  • 726 Answers
Is there a reset on the camera some were try reset it to normal settings
other wise the card slot is damaged and will have to be repaired
in the cam go to settings and look for any reset options and restore it
need more help plz reply
  • 421 Answers
You should try re formatting the card using the menu in the camera this may solve this also be sure your camera is compatible with this type of card and its size please rate -jeff
    Genius:
  • 2,035 Answers
This is the problem with camera try a remove the battery from the camera for 30 min and plug it back and check if you still get the same error ,if yes then you need give your camera for servicing ,Please click on these links:
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
Good luck...
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
When I turn on my camera it say my card is locked and I manually switched the little switch on the memory card however it still said it was locked so I bought a whole new memory card and it still says its...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 20, 2010 | Canon PowerShot A590 IS Digital Camera
After inserted A new batteries in the screen shows card locked how I can fix that
May 15, 2010 | Canon Powershot SX110 IS Digital Camera...
The card is locked. error
Move the slide switch on the side of the card.
Nov 22, 2009 | Casio Exilim EX-S500 Digital Camera
Card locked. Bought new card. Is in the
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 15, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera won't work because the sd card is protected
Jun 05, 2009 | Fuji FinePix Z10fd Digital Camera
Camera is saying "Memory card is locked. Slide lock to "write" position."
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
May 17, 2009 | Nikon D40x Digital Camera
Card locked
slide the little switch on side of card to unlock
Aug 24, 2008 | Cameras
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Memory Card Error - Locked
The likely problem is that the BIOS battery (NOT the rechargeable Lithium battery) has run low. This tiny, internal battery can be replaced without too much trouble by someone who doesn't mind disassembly of small parts, otherwise it's best left to a pro.
The battery is available from Canon or an official distributor, such as Huron Camera in Jackson, Michigan.
http://www.huroncamera.com/repair_parts.htm
Check the parts list. If you're squeamish, give Huron a call and arrange to have them fix it.
Dec 29, 2007 | Canon PowerShot A530 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
