Question about Watches
I don't know how to take some of the band off, to size the watch. It is a Mossimo AnaDigi Brace Watch. Please help!!
  • keri lomboy Sep 13, 2008
    My husband threw away the instructions for his new watch. I can't figure out how to take some of the brackets off of the band, to make it fit him. If someone could tell me how I would appreciate it.
Holding the Watch in your hand facing you, turn it to it's left side. You'll see a succession of small holes in the links wherein lies a removable hinge-pin, locate the link(s) you need to remove, and remove the pin in that link, and then the pin below it to pull the link. To do this, you need either a jewelers punch, (like a small awl, to push the pins out) or fashion one from a pair of pliers (small vise-grips work great for this) and a piece of a safety pin (cut a shank out of the back side of a pin to get a straight stiff shaft.)
When you pull your first pin out, put the watch on and gauge the size you need to make it.
once you have pulled the pins, note that one end of the pin is larger, and when reassembling everything, just take mind to put everything back in the same fashion as the disassembly process.
you'll have to push the pin in flush with either the flat side of some pliers or the side of a table, just make sure they go flush...
hope this helps, thanks for reading!
-Ross "Tweek" Sheridan
Posted on Sep 20, 2010
Mossimo watch instructions
If it isn't working, return it.
Nov 01, 2013 | Watches
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
Can the plastic band be opened? It won't fit over
you can ask for the instruction from the authorized retailer of your watch even that you don't have any proof that you don't purchase it to them. being the dealer of the watch brand it is their responsibility to assist all customers that need to know everything about the watch they selling.. now don't hesitate to ask them..
Jul 13, 2011 | Anne Klein 10-9119WTSV Watch
I need new band
If you need a new band for RADO watch, you can pop in any watch shop and choose whichever band you like. The only thing you have to remember is; get the right size. Right size for you watch is the size between lugs in millimetres. Lugs are the things where the band gets attached to the watch. Measure that distance - this is the size of band you are looking for.If you are after original Rado band, then you will have to pop into your nearest Rado dealer shop and order it. The real thing will be far more costly.
Mar 01, 2011 | Rado Diastar Classic 300M R12639023 Watch...
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    Need a new watch band
    mcdevito75 here, Ebay is a great place for your watch band, but you should know the watch band size in MM, or you can look for a small watch repair shop in your area.
    Jun 17, 2010 | Locman Titanio Tonneau LOC/484/CRBRD/BK...
    Men's Mossimo Chronograph watch has 1 stem to change the time and has a day and a month circle. How do you set them?
    if its the gunmetal one with the rubber wrist band you cant i just took it appart and there is noting to turn the analog day date or...what ever the other one is sapose to be there actualy just fake and are there to make the watch look fancy ..... f-n lame as sh!t
    Dec 13, 2009 | Watches
    Mossimo alarm
    While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
    Jan 29, 2009 | Bulova Men's Watch
    Getting analog part of Mossimo watch to start
    FIXED!!!
    As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
    Have the watch serviced to change the second battery and VOILA!!!!
    Enjoy!
    Mivales.
    Made in Costa Rica!!
    Sep 01, 2008 | Watches
    Mossimo watch
    Try this:
    http://www.webjeweller.com/jewellery/removelinks.shtml
    For my band, the trick is to use a 1mm jewler's screwdriver and push against the pin in the link. The pins exit in the direction of the arrow on the link (and go back in opposite direction).
    Pushing on the pin can be tricky. If you slip you'll stab your finger with the screwdriver. It takes a little more pressure than you think, but once the pin moves it comes out easily.
    Jun 21, 2008 | Watches
    Watches Logo
    233 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
