Question about Sony KP-61HS10 61" Rear Projection Television
Picture cuts out
My Sony KP-61HS10 set's picture goes black while I am watching it, though the sound continues. The red light in front blinks five times repetitively until the picture comes back. It is more frequent with bright colors like orange or white. I have the tv set to pro and the brightness and color turned very low to slow down the cut outs. Any suggestions? I would at least like to know what the problem is before calling in a repairman. The set is out of warranty.
  • 1 more comment
  • shanan Nov 24, 2007
    just received the kp53hs10 for free... the only problem is the standby timer light blinks 5 times and the tv picture will flash with the sound still working. The picture doesn't flash when a dvd is playing, however the standby light will still blink 5 times...any idea how much it will cost to repair this problem???
  • Tony Allen Dec 06, 2007
    i had 5 blinks and now i have 2 blinks. makes a noise when i plug tv in but nothing else functions after that. no picture/sound nothing. just red blink.
  • igger Jun 08, 2008
    My tv cuts off every 30 sec. (both audio and video). Reading through your posts, someone suggested to blow the dust off the light bulb and had succesful results. I tried the above described and now the tv does not turn on at all. The power light blinks red 3 times immediately after turning on.
    Any suggestions would be greatly appreciated.....
  • 513 Answers
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. The five blinks(count them again just to be sure) is an error codes that stands for the following: "FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly." So what is the AKB? It is Auto Kine Bias; a circuit that holds the video OFF until the picture tube (kinescope) is warm enough to run video. So, if there is trouble within the AKB it may not be turning on the crt. Or, the crt could be cold, or there could be power supply problems (which I favor because the audio is gone, too, which means it is not a "video only" matter). Therefore, I do not favor replacing the C board (or A board as indicated in the url above). I favor finding out why the AKB circuit is not functioning. It is necessary to get the set to come ON long enough to make sure the crt is heating up. You may have to manually defeat the protection circuit and force the set to come ON. If you can find the ON relay you may be able to hold it ON manually - at least long enough to find out more symptoms, but not too long or some further damage may occur. Go to: http://www.schematicsforfree.com/archive/?path=Sony%2FVideo where you may find a schematic or service manual for this set - or one that is close/similar enough to be of great value. Last comment: Some sets will, upon failure of the AKB function, after a few seconds, go into diagnostics - which is similar to protection. So, the audio may be working okey. Turn the set on with the volume up; if you hear audio for the until the set cycles into the flashing light routine it means the audio is really good. So, check that carefully. You may have to do a hard reset to cause the AKB function to reset. So, do this: Unplug the power cord for 4 hours or more. That will reset everything. Hope this helped, or gave you a general idea, but please don't take a further step unless you know the safety issues involved. Good luck
Posted on May 22, 2006
SOURCE:
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 blinking codes
You can get the service manual and free support at the following site to help yu with the repair of your sony the manual is 10.99 support is free here is the link. They will email the manual to you.
http://servicemanuals.vstore.ca/
Feb 14, 2008 | Sony KP-61HS10 61" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
626 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
