Question about Whirlpool ED2FHSS Side by Side Refrigerator
Whirlpool Refrig Side by side
The Control LED have suddenly stopped working ? Any ideas on how to repair ? Is their a fuse ? If so where ? The refrig seems to be working correctly Chris K
  • SOULCAREINC Jun 15, 2008
    MY FREEZER STOPPED FIRST THEN THE NEXT DAY MY FRIDGE STOPPED COOLING AS WELL...WILL TRY THE PLUG THING...AFTER THAT, WHAT WOULD THE NEXT STEP BE TO CHECK??
Had similar problem on KitchenAid KSRA25ILSS side-by-side, only the whole controls stopped responding (i.e. fridge/freezer got warm). Pulled the plug and reset the controller and is now running OK (knock on wood). Saved $70 service charge...so far.
Posted on Jan 03, 2007
  • 513 Answers
The problem is almost certainly in the controller or its power supply. Try pulling the plug for a minute or two - for some reason the display portion of the controller may have been sent out to lunch by a power surge or alpha particle. It woudn't be the first time. Check for bad connections between the display panel and the power supply and solder joints on the controller board. With everything else operational, a bad microcontroller chip is not that likely but is still a possibility. Good luck
Posted on May 22, 2006
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrig and freezer working on and off for 2 weeks
have you gone here with the model # and cked out what the site says...
https://www.repairclinic.com/?clearLs=true
without a model # is hard to help.
Jan 01, 2018 | Frigidaire PLHS67EGSB Stainless Steel Side...
Refrig. stopped cooling then the freezer side. then started back
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker is not making ice; the led light is not on. Water is working
possible bad led board. Usally there is a tech sheet under refrig located in the back side of grill telling you how to check
Mar 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
All the lights in the freezer are working. None of the lights in the refrigerator are working. All the bulbs have been changed. Is there a fuse in the refrigerator that would make the lights go out?
In your model , the refrig section light , gets its' power from the control board . When the lights stop working , so will the light for the temp adjustment display . The control board is located behind the refrig , at the bottom , on the left side , inside a white box . It is held on by 2 screws . The part costs around $ 80.00 , and is easily replaceable .
Nov 24, 2009 | Whirlpool GD5SHAX Side by Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
300 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
