Question about Asko T701 Electric Dryer
Asko T701 stopped running.
Dryer does not run.  Light turns on but pressing the start button does nothing (normally yo could hear the relay click and the dryer start - now nada.)  Fuses are good, reset button at rear is not tripped.
Washer is getting power thru the build in outlet. Im stymied.
    Genius:
  • 2,035 Answers
BeltDryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.OR you can use this link :
http://www.repairclinic.com/0088_8_1.asp#Level2_9
Good luck...
Posted on Sep 13, 2008
  • Asko Master
  • 19,396 Answers
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Asko t701 dryer won't start
If yourdryer is not starting then it is your motor. To determine this there is a trick you can try. First, put a piece a tape over the safetyswitch on the dryer. Take one hand andspin your drum of your dryer as your press the start button. If it takes off, then there is a bad spot onthe motor. Another thing is to try checkto see if you are getting 220 Volts to you outlet by taking a volt meter set at250 volts. Take the red leg of the voltmeter to the one side and the black leg to the other side. If the volt reader reads 220 then you aregetting the proper voltage. Finally, ifyou are getting 220 volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is forthe motor and leg is for the element.
May 11, 2011 | Asko T701 Electric Dryer
Dryer heating element works but tumbler stopped
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 06, 2011 | Asko T701 Electric Dryer
Start button will not engage
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Asko T701 Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
Asko T701 Dryer - Dryer Start Button
This would have to be your door latch, in my opinion. The door simply is not holding in the button.
Dec 07, 2008 | Asko T701 Electric Dryer
Asko T701 Electric Dryer Logo
221 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
