Question about Dehumidifiers
Tripping BreakerS Tripped breaker. Took unit apart, Cleaned it . Reassembled. Tripped again. Ordered new humistat switch. Installed new switch. Tripped again. Opened unit again and searched for bare wires .found none. It seems to trip breaker every time it is turned on. Could use a wiring diagram to make sure its wired back up to humistat switch correctly.
  • billpcr Sep 27, 2008
    Everything is clean and basically new. The breaker trips after about 3 minutes every time. Sound is normal for a while, then changes, and the breaker goes.
  • CiViCKiDD May 09, 2009
    I have the same exact problem and have been trying to figure out how to fix this. I'm thinking I don't have a choice but to replace it since nobody seems to have a fix...?
I have the same problem with a new lg unit...it will trip the breaker after a few minutes of being on.
Posted on Oct 31, 2008
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Posted on Oct 02, 2008
Kenmore dehumidifier 25358400890 sometimes works, but sometimes won't run. Light comes on when bucket is removed, so it's getting power. Any clue why?
Assuming you've turned the humistat all the way to the maximum dry setting, it's possible it's not humid enough for it to run but fairly unlikely. The humistat may need to be cleaned or replaced or the compressor may be low on freon. If it works in hotter temperatures this may indicate low freon. Freon pressure increases with temperature therefore if it's hot, the pressure inside may increase enough to satisfy the low pressure switch.
Jun 01, 2014 | Dehumidifiers
Starting tripping circuit breaker
Good Afternoon Dennis - Often when this occurs, it is because there are too many appliances on the circuit or something may have a weak or poor breaker. Try plugging the unit in a different location or on its own circuit. If the issue continues, then it could also be possible that something shorted within the unit. So in this case, because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage. Thanks for allowing me to help you.
Jul 28, 2013 | Frigidaire FAD504TDD Dehumidifier
I'm testing my daughter's dehumidifier that blows her fuses. In my house, it does not blow my circuit breakers but does trip my GFCI outlets. What do I need to do?
If you are blowing fuses and GFCI's your compressor is either not starting at all, is starting hard, or is at least grounding out momentarily...
at any rate the compressor is failing, and that is not economically replaceable..
heatman101
Sep 25, 2011 | Maytag M7DH65B2A Dehumidifier
The dehumidifier won't run. I adjust the humidistat up and down and nothing. worked fine up until that point.
Brad, there are several solvable things that can cause this:
1. The water collection bucket is not installed properly. Remove the bucket and reinstall it in such
a way that it fit's "squarely" into it's holder from top to bottom and makes contact with the bucket
safety removal switch on the back wall of the holder. When installed properly, the bottom of the
bucket will not tilt down at all.
2. The float valve in the top of the bucket (if yours is equipped) is either stuck in the 'UP' position or
float valve arm is broken. If it's stuck in the up position, jiggle the arm of the valve to make it
return to the 'DOWN' position. The float valve arm can be replaced if necessary. But in some
cases, you must purchase a new bucket with one already installed.
3. The outlet the unit is plugged into is faulty. Check your home's circuit breaker panel for a tripped
circuit breaker. If one is tripped, unplug the dehumidifier before resetting the breaker. If none is
tripped, check the outlet for power. It may have a loose or damaged wire on one of the terminals.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 17, 2011 | Goldstar Dehumidifiers
Hi my Danby DDR4588EE Dehumidifier's buttons aren't working
Hi! I'm assuming that the unit is plugged in and the outlet the unit is plugged into is working (if not, is there a tripped circuit breaker, in your home's circuit breaker panel?). Also, that you have turned ON The Master ON/OFF Switch and the Water Collection Bucket is installed properly and the Float Valve inside the bucket is in the Down position
If you answered NO to any of the above, turn the the Master ON/OFF Switch to OFF and unplug the unit, before checking those things first. Because, 9 times out of 10, one of thee above is the culprit.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 18, 2011 | Danby DDR4588EE Dehumidifier
Won't power on
Several things could cause the dehumidifier to not turn on. It could be the switch itself, or the power cord, or some internal component. If you have a multimeter, you can take the unit apart and test the switch and the power cord.
Also make sure the outlet is getting power and no circuit breaker has been tripped.
Jun 16, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
Soleusair 14k btu compressor not running otherwise unit seems ok, just wont cool
verify voltage to compressor terminals and capacitor, if the unit is not blowing fuses or tripping breakers, it could be the start components or the compressor itself.
Jul 20, 2009 | Dehumidifiers
Kenmore model 580.54701 70 Pint dehumidifier
Evaporator fan is not turning on - a problem with almost all dehumidifiers... probably on this unit (being so new) it's the control circuitry (in the circuit board) which switches the fan on...
I have the same unit with the same problem)
Sep 07, 2007 | Kenmore 54701 Dehumidifier
DeLonghi Dehumidifier pump out failure
I have the same problem. Very annoying. My suggestion is to go to your nearest dealer and throw the unit through their front window.
Aug 02, 2007 | DeLonghi DE500 Dehumidifier
Dehumidifiers Logo
352 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
