Question about Toshiba 57H81 57" Rear Projection Television
Toshiba big screen
Did you ever get your bigscreen fixed with the ic convergence issues?
  • rickkcid Sep 15, 2008
    what did it end up being?
Yes. I did get my Toshiba 57H81 Fixed. But the remote control doesn't work afterward. I have to pull the mainboard out again to see if there is any problem during the IC replacment.
Posted on Sep 15, 2008
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 61HX70 61" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
I have a toshiba big screen tv we believe both convergents need to be replaced we do not have 300-365.00 to repair it . I know how to solder can I do it myself???? model#57H81
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Toshiba 57H81 57" Rear Projection...
What do convergence chips look like
This is what a convergence IC looks like.
Oct 19, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba big screen The tv is like double exposed . I have a toshiba big screen tv and I have double images in red and green. How do I fix this problem?
This is likely your convergence ICs(chips). If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills. you will find the ICs on the largest heatsink in the tv. the part number starts with STK. if you replace them, check the resistors in front of them and replace accordingly. most toshiba will blow up to 3 fuses (f850, f851, f852)
Dec 08, 2008 | Televison & Video
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Problem with TV screen?
Good Day, deon453;
Sounds like a convergence problem.
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
version.
Jul 02, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Convergence Output IC Failure
version.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
T.v. problem
This is a convergence issue. Have you tried going thru the convergence touch-up thru the menu?. If you have and it does not cure your problem, the convergence ic flat packs have to be replaced. The average repair is around $200-400.
May 07, 2008 | Televison & Video
Toshiba big screen tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Jan 05, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
