Question about Dishwashers
Cancel drain light continue to flash and dish washer will not make a sound
    Novelist:
  • 171 Answers
Hi sandsmi8,
I'm Harvey the Master Plumber.
You're telling me only: cancel drain light continue to flash and dish washer will not make a sound.
Based on this info alone you might be able to reset the d/w with power interuption. Try turning off the breaker for ten minutes. With some models this will reset the d/w computer. If that dosen't work you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
My kitchenaid dishwasher kudc101xbl4 won't quit running or cancel / drain button light stays on and none of the other buttons work
If you wash your dishes off before you put them in the dish washer the sensor for the food particles won't pick it up and it will keep running. My repair man told me when he repaired my dish washer.
Sep 23, 2014 | Dishwashers
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
