Question about ASUS P4XP-X Motherboard
Cannot boot no beeping after remove the HD and Network card. only RAM in place and video card but still no beeping.
  • 1 more comment
  • Howard Lester May 11, 2010
    Silly question,but do you have the four pin connector connected to the board as well as the 24 pin.It won't boot without it.
  • Mike Peluso
    Mike Peluso May 11, 2010
    Maybe your internal speaker is bad.
  • Mike Peluso
    Hi Tony, did the system every sound off with P.O.S.T. ? Power On Self Test. POST only checks the motherboard, memory & video card. Though you'll never get the system to boot without a hard disk drive connected.
    Other Items you should notice at boot up. Does the CPU fan run? Does the case LED's light up? Does the floppy disk drive (If you have one connected) light up?
    CD-ROM drive's LED flash. Personnally you should have the primary hard disk drive connected. Are you able to enter the bios menu & see display on a monitor? The internal PC speaker can be removed from the board & you can run an OEM test, (Using an OEM meter) across the two speaker wires, which will conferm the speaker is good. The Asus P4XP-X came with a built in VIA VT6105L 10/100 nic card. The nic card can not be removed. Did you disable it in the bios? Or did you add a new nic card? Please explain "in more detail" why removed the parts.
    Mike
Saya punya komputer tidak boot up dan tone pun tidak berbunyi, awalnya komputer saya bawa dengan kendaraan setelah dipasang tidak berfungsi, power supply berfungsi. kira kira kenapa ? mohon informasi.
yuda
Posted on Apr 16, 2009
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
Video Card won't work, just beeps.
This model video card requires 1Gb of system RAM for it to oerate properly.
Check your RAM modules they maybe faulty.
The specs for this graphics card are on this WEB site.
http://www.amd.com/la/products/desktop/graphics/ati-radeon-hd-2000/hd-2600-pro/Pages/ati-radeon-hd-2600-pro-specs.aspx
Mar 06, 2012 | Computers & Internet
Acer aspire m3201
Check the RAM module/s, try reseating them first, if it still does not boot up the remove the RAM module/s and take them to your friendlt computer repair shop and get them to test the RAM for you.
Feb 09, 2012 | Acer Computers & Internet
My computer lets off a constant high pitched beep when I turn it on - and the monitor doesn't display anything
hi,
there are generally two reasons for the high pitched beep either a faulty RAM or an faulty Video card first try to remove the ram clean the contact areas and replace it if the problem still persists then do the same with the video card, if the thing is still nagging then replace either of the components one after the other to check which has a problem
hope this helps
May 24, 2011 | Hightech HIS H695F2G2M RADEON HD 6950 2GB...
I have A dell gx270 desktop computer . i was searching on internet . Suddenly system hangs . When i restart computer it hangs on dell logo . i tried many time but it hangs on dell logo . i changed ram ,...
Firstly, make sure you installed the video card (if it has one) back into the same slot it was removed from.
If you are using on-board video, check the CPU is firmly seated into it's socket, you may have to remove the CPU fan to check this.
Next, check your RAM sticks again. Most (about 98%) of boot up issues arise from incorrectly seated ram sticks or ram sticks that have developed connection issues.
When you boot the machine, does it make any beeping noises..?
Usually, a single beep means all is ok. If you hear multiple beeps, then the bios is telling you about a possible fault and you should count the beeps for number and duration (long beeps or short beeps and how many of each and in what order)
Remove the ram and using some very fine emery cloth, gently remove any oxidisation from the contact pads to return them back to bright metal, then re install them making sure they are seated all the way down and the locking clips are fully seated too.
If you still have boot issues, I would suspect the ram sticks first and have them checked by installing them in another compatible machine, either a friends or at a repair shop.
I would suspect the board last so if the ram sticks check out as good, have a closer look at any other cards that may be installed, especially video cards and internal modems but also check out any network cards that may be installed..
If you are still not getting any display on the monitor, take the machine to a service centre or computer shop as they have the specialist equipment to check out the board electronically ( boot cards, scopes etc).
Let me know how you go and what you find..
swoop611
Dec 05, 2010 | Dell OptiPlex GX270 PC Desktop
Before booting 3 long beeps 10 sec silent then 3 long beeps and so on
This is an issue that one of the devices is not properly seated on the board or it is not detecting them correctly.
To fix:
1. Remove all devices from the board. All cables coming from Hard drive/CD-rom. Remove the RAM and processor. LEAVE TH E POWER SUPPLY CABLES CONNECTED TO THE BOARD.
2. Re-seat the processor on the board.
3. Re seat the memory on the board.
4. Now re-seat the video card making sure that you push it firmly in place. Connect a monitor to the video output.
Try and boot the computer. If it boots and you see output on the screen then the issue is fixed.
If if does not boot you have a problem with one of the following: RAM, Processor, Video Card, or motherboard.
Oct 30, 2010 | Asrock K7VT4A-Pro Motherboard
Computer would not post no beeps heard. i have also tried reseating the ram but no go. Please help.
reasons for no post are the bare basics,
Video
Ram
Power
you should remove everything else HD doesnt need to be attached to post. retry the boot. if no post try to force a beep code by removing the ram. if it beeps its video if it doesnt its mobo.
some boards dont require video, so if video isnt present or not working it will post normaly and give you no beep codes (Bios thinks nothings wrong).
if removing everything but video and ram works try reducing power consumption or get a bigger power supply.
Jun 10, 2010 | Computers & Internet
Ive got a long continual beep and it emits orange light from the front and back of the computer how am i to fix it?
Turn the computer off.
Unplug the power cable.
Remove the video card.
Remove the RAM.
Re-insert the video-card, ensuring that it is "seated" properly.
Do NOT re-install the RAM, just yet.
Connect the power cable.
Turn the computer on.
If you get a different "beep", the lack of RAM is the problem.
If you get the same "beep", the video-card is the problem.
Disconnect the power-cable.
Re-install one stick of RAM (two if it is RAMBUS/RDRAM).
Reconnect the power-cable.
If it beeps "normally", then the not-yet-installed RAM is the problem.
If it still "long-beeps", turn the computer off, disconnect the power-cable, and remove the RAM, and insert the "other" stick/pair of RAM.
Reconnect and start it up.
If still a problem, change the video-card.
Dec 02, 2009 | Dell PowerEdge 1800 Server
My pc doesn't boot anymore.
This code usually refers to a Video card or RAM issue. Try reseating both the video card and then RAM to see if it fixes the problem. If not then try removing the video card and rebooting. If the system starts without the beeps then you'll know the video card is bad and you can replace it. If it still beeps then try removing the RAM one stick at a time, rebooting after each removal. When it boots you'll have the bad RAM stick isolated and can replace. Hope this helps.
Oct 11, 2009 | ASUS P4P800-VM Motherboard
ASUS P4XP-X Motherboard Logo
237 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
