Question about La Pavoni "PROFESSIONAL Chrome" 16Cup
Water too slow
I have a europiccolo and gradually the water has run more and more slowly. I now have to force the lever up to get water to run through.
Previously once the lever was raised it would stay there until the coffee started running through in about 5-10 seconds
Is there an adjustment to fix this? (I have tried varying the grind etc and that didn't help)
Thanks
  • muddo Nov 15, 2008
    Thanks Rajuraja, I'll give it a go!
  • muddo Nov 25, 2008
    Hey Rajuraja, you're a genius! It worked! Back to as new.
    Although it was actually a little easier than you suggested - once the circlip and pin were removed with the handle up, I just put the bolt back through and used that to tighten it back up all the way. Didn't need to take the plunger out or to remove the group - although I did do that and gave it a ll a good clean and re-lubricated.
    Anyway, you're a champion. Saved me $$$ and many days with no coffee...!! Thanks heaps
Most probably the plunger has unscrewed. You need to remove the plunger from inside. Remove the bottom circlip and remove that pin so that will be disconnected from the plunger mechanism. Remove the bolt and washer on top of the plunger, remove the group and than smartly tap with a rubber mallet to remove the plunger mechanism from below. You will probably notice that the shaft is unscrewed from the ceramic plunger though not all the way. Tighten this and clean inside the group. replace the mechanism from below and replace the sieve with the rubber o-ring seal - you will have to use a screwdriver or similar implement to secure the o-ring in the space. Replace the pin for the handle insert the circlip and replace washer and bolt. You are good to go.
Posted on Nov 13, 2008
That is most likely the issue & answer as described by rajuraja. For a quick, temporary fix—remove the lever pin that goes through the piston pin and then with a wrench, carefully turn the piston clockwise maybe 2 or 3 full turns. Be careful not to scratch the chrome on the grouphead. I turn and simultaneously lift at the same time. This keeps me going for several days, until the piston gradually unscrews itself. Put a couple of drops of PLA Turbo-Lock High Temperature Thread Lock on the threads of the piston if you decide to take the entire unit apart. Available at orphanespresso.com
Posted on Oct 28, 2009
When the cycle finishes, there is water in the bottom of the dishwasher this begins to smell
there is some kind of clog in the drain system. clean the screen in the dishwasher, there gets a build up of food, or misc stuff in there. it is probably draining, but slowly.
the dishwasher usually has a pump that pumps the water out with force, but if clogged it will be slowed down and when the cycle stops there will be water left in bottom
hope this helps
rick
Jul 15, 2011 | Dishwashers
When the lever on my Vestige faucet is turned to the hot side, it chatters and stops running when the hot water reaches it.
It sounds like you have a foreign body in the hot line,turn off water both cold and hot disassemble handle assembly including springs and washers slowly turn on hot water to see if object will flush out,if not disconnect hot water supply to faucet the turn on water supply slow ly to see if object is in supply line.If that dosen't work you may have to call plumber it may be in supply stop or below it and you need a professional to handle that.
Jun 10, 2011 | Moen 7065ORB Vestige Single-Handle Kitchen...
Hot water slows to a trickle when lever turned to hot. Cold water has pressure. All other faucets in house have pressure
sounds like you have trash in hot side of value or cartridge...shut off water remove cartridge....check for trash....turn on water slowly to clear lines...may take 2 people to do this 1 to turn water on while other sees if water comes out both ports in value....look in cartridge to see if any clog....if you can get a bucket of soapy water before hand and wash cartridge under soapy water...reinstall and check....if water comes out off both ports without cartridge in...when you reinstall after cleaning it still no flow...you may need new cartridge,,,good luck
Jan 24, 2011 | Dmm Symmons Temptrol II pressure balancing...
Leacking coolant fluid slowly
There are several ways to check this problem. The most reliable is a Radiator pressure tester which you might be able to borrow with a deposit from Autozone or Oreillys or Advance. The old-time Service stations used to use them. For sure Radiator repair shops still use them. The idea is to put air pressure in the water system and force the water out of the leak. Sometimes chemical tracers are added to expose tiny leaks.
What does not leak externally would have to be leaking internally.
Looking at your Radiator fluid you should not have oil in the Antifreeze. Then look at your oil dipstick. The oil should not have a white or yellow frothy appearance indicating water content or Antifreeze content. It is possible to leak water into the oil crankcase and the water will partially evaporate leaving the frothy residue.
Once you determine the source of the leak you can make decisions. Internal leaks are the most expensive to fix. These would be internal things like head gaskets. Evidence of head gasket problems are oil in the Antifreeze and Antifreeze in the crankcase or frothing. It is worth it to try a modern leak-stop. This is one area where modern chemicals are better than products of the 1950's.
But do not use leak-stop for hoses and water pump problems. Hoses are cheap to replace and water pump seals and gaskets are subject to erosion from the flowing water.
If you can not find anything through this testing, put a page of newspaper under the interior carpet by the Heater core. A slow leak can drip on the carpet and gradually soak in before you discover it.
I hope my solutions help you fix your problem.
Jan 11, 2011 | 2001 Mercury Mountaineer
Water dispenser runs very slowly. it doesn't seem
If it's not the filter, then the water valve is most likely defective
Oct 30, 2017 | GE Monogram ZFSB26DRSS Stainless...
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
Watner dispenser gradually stopped working (slow flow to begin with)
you need to change the water filter, usually around $35.00.
May 23, 2009 | Maytag MSD2758GEW
La Pavoni "PROFESSIONAL Chrome" 16Cup Logo
308 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
