Microsoft Windows XP Professional for PC
Problem for Microsoft Windows XP Professional for PC
Auto restart?
By silly girl on May 17, 2006
I get back home from work every day, and I find that the internet connection got disconnected, certain programs that usualy come on on start up and I close them are open, and nothing is open - no open explorer windows, no browsers open etc.
Am I right to suspect that the PC is restarting on its own?
What is causing this?
no one else has been in the house, and I checked and everything is normal in the power options in the control panel.
I only left emule running, and maybe firefox.
Any help will be appreciated.
Comments:
May 18, 2006
- Not sure what to do...
As I said, checked the power options, and the only thing that on there is the screen thing. And I haven't done a thing to provoke this, just left it running in a well aired space.
carlos - that's not me rating you BTW.
About turning PC off VS. leaving it on - I was under the impression that they design the machines today to like being open all the time. Isn't that so?
Best Solution
posted on May 17, 2006
Very Helpful)
techman
Rank: Guru
Rating: 86%, 7687 votes
SillyGirl
if you go to control panel and the n power options do you have any thing like the hard drive or monitor to hibernate??? go to the hibernate tape on top to see if its enable or disable. if its disable Im not suere but a possiblity that some on your IP addy and comming into your puter??? Or maybe you have a power supply overheating problem and the power supply shuts down intermittantly?? I know alot of peeps say they leave there puters on all the time but why??? if your not using the puter as a slavr or a main hub then why not conserve energy and turn it off???? just a thought as i alway turn mine off if I leave the house or go to sleep but its on when im home cause im usually doing some drawings on cad Good Luck
Was this helpful?
Yes
No
Solution #2
posted on May 18, 2006
Somewhat Helpful)
carlos-aec
Rank: Master
Rating: 82%, 128 votes
Hi:
I agree with the opinion that computers are supposed to be shutdown while we are not working on them... let's see: not only you will spend less energy as your operative system (in this case - Windows XP) will reload all the programs and information needed... and this is a true time save because your computer will run faster...
But let's focus on the issue:
- if that was provoked by you, don't do it again because each time you do something like that, Windows will accumulate errors...
- if the problem is with the software (like you cannot have access to your Windows) you should use the "System Restore" Tool. It's a good tool for domestic computers and the common user
If you need more detailed info just post again
Regards
Was this helpful?
Yes
No
Solution #3
posted on Dec 24, 2008
Not Rated)
Loteck
Rank: Wiz
Rating: 82%, 84 votes
Maybe some malware has taken over your computer. It can happen.Turn it off when you are not using it. Saves energy! Your E-mail is being saved in a server somewhere. You will still get it.
Was this helpful?
Yes
No
Solution #4
posted on Feb 19, 2008
Not Rated)
allen23
Rank: Apprentice
Rating: 0%, 0 votes
Go to your start button, then run, a window will pop up. On the line type in msconfig. When the box pops up go to the last tab on the right which should be the startup tab. When that tab opens you'll see a list of your active programs. Go down the list of programs and disable the ones that you don't want working during the time you're not at home. Re-start your computer and this should solve your problem.
Was this helpful?
Yes
No
Solution #5
posted on Aug 19, 2007
Not Rated)
dikla
Rank: Guru
Rating: 85%, 172 votes
some emule's can cause the computer to restart did u try leaving the computer on without the program emule running to see if this still happens?
Was this helpful?
Yes
No
Solution #6
posted on May 30, 2007
Not Rated)
vmitchell85
Rank: Apprentice
Rating: 74%, 5 votes
You might want to try running the Apple Hardware Test(AHT), to check out the hardware. How to run the AHT depends on your computer model, you should be able to find it on apple.com/support
If you find nothing then maybe running Repair Disk from the CD... Link to Directions:
http://docs.info.apple.com/article.html?...
Hope this helps, I used to do technical support for apple... Post back if you still need help...
Or you can check out Apple's discussion boards on their website.
- Vince
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional for PC?
Answer
Answer
How do I get rid of''compile error in hidden module: AZWizardModul'' every time I start up Microsoft... (More)
Answer
grey menu selection tab remains on top of the screen even after the selection is over. Goes away... (More)
Answer
Windows Vista administrator password is the password to an account configured with administrator... (More)
Answer
pc dvd game not displaying after installation in windows xp professional
Describe your Operating Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in , ME
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
