Question about Directv Sat-Go Portable Satellite TV Receiver with 17" LCD Screen
No sat-go reception
Sat-go reciever purchased used.Have confirmed reviever/lcd and rg-179 cable work as have hooked up to my directv sat.The programming is not my subscription, appears to be previous owner in CT. I live in CO. Have been in contact w/Directv for setup confirmation, not a lot of expertise from rep. Never did ask for RID or card number, not sure if this matters. Numerous attempts to set up failed, have confirmed round dish single lnb and new zip (80503) w/ 164 azmith and 44 elev. as per directions. Have even pushed rest button, but didn't seem to affect any change. No registered response from any sat or transponder, if continue to set up end unit will cycle between searching for sat and downloading guide banners.D-tv rep says sat unit is steady state and w/no damage visible to unit- is working. Can moving unit across country cause it to get lost- like GPS?
  • bprice08 Sep 27, 2008
    Have the exact same problem. Finally got a little support from Direct TV and they tell me that the units are not repaired by Direct TV. If one fails under warranty, they replace the entire Sat-Go system.
  • 46 Answers
I believe there is a special package that you must have to use this item. Contact directv sales.
Posted on Jan 24, 2009
Error 771
ok explain a little more please. Make sure U have the coax coming from the Dish (outside) going into the back of receiver where it says SAT in. or if it is a dual tuner (ie: 322 etc) make sure the coax in hooked up to the Separator. also make sure u are using the correct dish and lnb to match ur receiver. I ALWAYS do a "check switch: every time I hook up to a new/different dish just to make sure the receiver recognizes the LNB.
Sep 02, 2014 | Directv D10 DTV Receiver
How to hook up the antenna
If you are not using cable or Sat. TV, you need a DIGITAL outdoor antenna, preferably outdoors for better reception. Forget the garbage indoor window or set top systems as they will not pull in a good signal, unless you are near the TV Stations transmitters. Cosco or WalMart has TV Outdoor systems.
Apr 02, 2014 | RCA P46924 46" Rear Projection Television
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
My sound just went out and the picture is fine
Be sure the speakers are "on" on the menu......un plug it and your cable or sat reciever for a bit and re start them both. Lastly see if problem still there on a dvd player........if so............it may need a main board. You may be able to circuimvent by getting sound thru a surround or amplified spkr set up and hook to your cable or sat reciever too
Jun 04, 2010 | RCA L42WD22 42 in. LCD Television
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
R10 receiver
one wire should be going out the wall or through the wall, that wire goes to (sat in) port. If your other wire goes to the tv, that one goes to the (out to tv) port.
Jan 22, 2009 | RCA R10 DIRECTV Receiver/DVR with TiVo
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Second DirecTv box unable to locate a signal
it is multi sat multi sat compatable!My opinion is buy a powerd multi switch you can getem at radio shack or from a sat dealer that will clear p your prolem i belive also check all your rg6 coax ends u may have a a bad splice or a fraid shiel wich will make your reciever do the same thing but hope you can fix it
Goodluck
Please rate
Dec 11, 2007 | Televison & Video
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Directv Sat-Go Portable Satellite TV Receiver with 17" LCD Screen Logo
238 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
