Question about Apple iPod nano 2nd Generation MP3 Player
How to save songs from my nano (the old ipod nano)
I had downloaded songs to my ipod... my computer crashed and i want to save the songs that I already have on my nano without losing any of them when I reinstall itunes. Is there any way it could be done?
    Filmmaker:
    Uploaded 5 video answers.
  • 15 Answers
I used TouchCopy for this, it's the best <a rel='nofollow' href="http://www.wideanglesoftware.com/touchcopy"> iPod transfer</a> software out there. It copied all my iPod songs, videos, playlists and photos to my to my new computer.
Posted on Dec 02, 2009
    Problem Solver:
  • 6 Answers
All you need is to transfer all existing music/videos on your iPod back to your computer and iTunes. In this case, all songs/videos are on your new iTunes library that you can syn with whenever you wish to without deleting any files.
For a better transfer, I recommend this iPod transfer program.
With a few simple clicks, it will help you transfer all music/video (both purchased and non-purchased) from iPod to computer, and then you can easily add those songs back to iTunes.
It even has detailed guide on the whole process.
Hope this helps.
Posted on Mar 03, 2009
I'm not sure how to fix this on a PC, but if you are on a Mac, its very simple.
There is a program called "Podworks". This will read directly from an iPod and it will restore any or all songs back into iTunes or to a location on a disk drive.
Podworks will also recover you playlists as well.
Good Luck.
Posted on Dec 17, 2008
    Problem Solver:
  • 7 Answers
This is actually pretty easy. If you're using Windows, all you need is a little free app called share pod.
It's available here:
http://www.sturm.net.nz/website.php?Section=iPod+Programs&Page=Sharepod
Posted on Nov 16, 2008
All of the songs on your ipod are in a hidden folder. If you connect your ipod then go My computer/****'S IPOD then go to tools - older options - view then set it to show hidden files you can view all your music files. However all the files are renamed, so you'd have to go through and identify each song
Posted on Oct 03, 2008
  • 31 Answers
You want to back up your ipod music . you need to transfer music from ipod to itunes or onto computer. you can do this with software or manual music transfer from ipod to itunes.
Posted on Nov 10, 2008
  • 2,071 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Hope it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 13, 2008
SOURCE:
Download to ipod
How Do I Download Songs Onto My iPod Nano?
IPod Nanos are portable multimedia players that allow you to playback songs and other content (e.g. video) no matter where you go. They come in a variety of memory sizes such as 4GB or 16GB (gigabytes) and work with iTunes to upload songs. ITunes is the iPod default management program which allows you to upload songs to its library, create playlists and sync music on your iPod quickly and easily. This simple process will have you jamming to your favorite songs in no time.
Downloading to an iPod Nano1Connect your iPod Nano to the computer using the USB cable. Launch iTunes if does not automatically launch. When you launch iTunes, it will display your iPod Nano on the left panel.
2Add music to your iTunes library. Click the "File" button on the top menu and click "Add to Library." Locate the song you want to upload to your player and click "Open" to load it to your program.
3Click the "+" button on the lower left panel to create a playlist. Type a name for the playlist and drag the uploaded file to it. To upload additional songs, repeat Step 2 and drag the uploaded additional songs to the created playlist.
4Drag the songs in the playlist up or down to select the order in which the songs will play.
5Sync your iPod Nano. Click the iPod icon on the left panel after importing songs and adding them to the created playlist. Click the "Music" tab and click "Sync music." Click "Select playlists, artists and genres" and select the playlist you created that contains the songs you want to upload. Click "Apply" to automatically sync and download the songs to your iPod Nano.
6Click the "Eject" button and disconnect your iPod from the computer.
Tips & Warnings
Click "Music Store" if you want to purchase a music file. Search for the song on the iTunes store and download it to the iTunes library.
Nov 23, 2011 | Apple iPod nano
How can i download song in ipod plz
hi,
you can save/download songs from your computer to the Apple iPod by the use of itunes. you need to install itunes first on the computer before you can manage the music files from the comptuer to iPod. itune is converting the file names recognizable only to iPod. Cheers!
Sep 10, 2010 | Apple iPod nano
How to down load a song to my appleipod nano 2gb?
To download songs to iPod nano: m Simply connect iPod nano to your computer. If iPod nano is set to update automatically, the download begins. Important: The first time you connect iPod nano to a computer, a message asks if you want to transfer songs automatically. If you accept, all songs, audiobooks, and other items are deleted from iPod nano and replaced with the songs and other items from that computer. If you don’t accept, you can still download songs to iPod nano manually without deleting any of the songs already on iPod nano. While music is being downloaded from your computer to iPod nano, the iTunes status window shows progress, and the iPod nano icon in the Source list flashes red. When the download is complete, a message in iTunes says “iPod update is complete.” If you set iTunes to download music manually, you can reset it later to update iPod nano automatically. For more information, see “Updating iPod nano Manually” on page 22. To reset iTunes to update iPod nano automatically with all songs and playlists: 1 Open iTunes and select iPod nano in the Source list. 2 Click the Options button and click Music. 3 Select “Automatically update all songs and playlists.” The download begins automatically.
if you need further assistance please let me know. Thanks, MIDWEst-tek
Aug 31, 2010 | Apple iPod nano
Can't transfer songs from old ipod to new ipod
Try to transfer them from your computer and dont copy from one playlist to another.. Also make sure that you transfer the songs from one to another ipod using the same computer.. Maybe this is the problem
Dec 30, 2009 | Apple iPod classic MP3 Player
How do i download songs onto my ipod nano
Apple iPod Nano devices are using itunes.
Every purchase or Apple iPod unit are given a disc which to install iTunes in your Computer.
If you don't have one you can download at this site.
www.yboyandrei.com/itunes
Sep 11, 2009 | Apple iPod nano 4th Generation
How to transfer songs from Appleipod to Laptop and itunes library
There is a guide for you http://support.apple.com/kb/HT1367
Here is another one http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/transfer-music-from-computer-to-ipod-between-computers.html
Jul 23, 2009 | Apple iPod nano
New computer...old ipod
In the main screen of itunes check the box called manually sync and update songs , With this method you can keep your old songs intact and update and new songs .
Aug 06, 2008 | Apple iPod nano
Frozen iPod Nano
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
Jun 22, 2008 | Apple iPod nano
Apple ipod
You need to get ITunes, and then go to your limewire library, select the songs you want and press Enqueue and then press save file, save it to your documents and then go to Itunes, press file, import, then click the file you saved and it will automatically upload all the songs you saved, once your done plug your ipod into the computer and it will open itunes and download the songs to your IPOD
May 28, 2008 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
1,431 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
