Creative Zen would shut off if bumped, now it doesn't turn on. How can I do my own repair.
  • kekoe7 Sep 13, 2008
    Solutions don't help when the unit doesn't turn on. USB port(s) work fine. Unit doesn't turn on.
    How do I repair?
  • 2,071 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Posted on Sep 13, 2008
My zen won't power off
Some ideas
  1. First, try a reset: Insert a paperclip into the reset hole at the bottom of the Vision
  2. Or, try running off mains power, not battery (in case you have a dead battery)
  3. If you're able to get in to the system, try going into Recovery Mode (see below)
Otherwise, if you have a dead unit, consider returning it to the place of purchase, or contact Creative to get your machine repaired. If the Zen is less than one year old, you should be able to get it repaired under Creative's warranty. For details on how to do this, go to uk.europe.creative.com/support/warranty , or you can call +353 1 4333200.
Jul 23, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen shutting down
Update the firmware that creative put out you should be fine from there.
Apr 23, 2009 | Creative Labs Zen V MP3 Player
My creative zen wont turn on
I would request that you return the MP3 player to its rightful owner
Apr 04, 2009 | Creative Labs Zen V MP3 Player
My creative zen freezes up while shutting down
Mine froze while trying to add radio preset stations. Had to put a pin in the reset hole to recover.
Have tried to understand 'playlists' without success!
Mar 05, 2009 | Creative Labs Creative Technology Zen MP3...
My crative zen moziacv lx shut down
charge is then if dat doesnt work go to zen website and get the mp3 player recover program
Feb 10, 2009 | Creative Labs Zen Touch MP3 Player
Creative ZEN - Display is NOT working, but audio working fine.
I had the same issue with my older Zen Xtra 30GB. I contacted Creative and they wanted 125 USD to repair it, but I had only had it about a year, and I paid 200 USD for it. The warranty on Creative products is only 90 days. I love their stuff but their support and repair policy is horrible. I shut it off and left it alone for a couple weeks, and the display started working again. It developed a charging issue though and even after replacing the battery it never worked right again. Try leaving it turned off for a few days or so. If it doesn't cone back, I would suggest looking into a new player. They are not worth fixing at the price Creative wants. iPod nano 8GB players are down to 169 dollars now, and as they are the standard now, there are more accessories available for them. The warranty is also a LOT longer.
I switched and I could not be happier.
Cheers
Dec 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen V plus screen fail/constant charge glow
· http://www.zenrepair.com/Zen/index.jsp
Sep 15, 2007 | Creative Labs ZEN V Plus MP3 Player
Trouble turning on and off.
do you have all the latest firmware?
and is the battery good?
try creative recovery tool
http://www.anythingbutipod.com/archives/2006/02/how-to-disassemble-the-creative-zen-vision-m.php
Jan 01, 2007 | Creative Labs Zen Micro MP3 Player
206 people viewed this question
 Grubhead
Grubhead
