Question about Philips 60PP9352 60" Rear Projection Television
Convergence Problem? I have a Philips 43" rear projection HDTV that is giving me problems. Splotches of yellow, blue ghost outlines, etc... starting showing up when I turned my TV on 3 days ago. If I turn the TV on and off several times in a row it will usually go away. Repair centers are saying its a convergence problem. They don't do house calls and are going to charge $400+. What can I do to fix this tv that is only 3 years old? What do you think about gearslip's converger tool?
    President:
  • 3,130 Answers
As many projection sets I have worked on and set up i didnt know they had deguassing circuits??? Ummm Hold on a second. Nope just looked in a manual they do not . I dont mean to shoot down sillygirl really I dont. Ok to the problem at hand. Yes your problem could be a convergence problem and 400 is about average for this repair if its done correctly. And that would be replaceing all the convergence ic's at once and resoldering all the regulators and larger resistors on the pc board . But the problem you speak of sounds like the liquid coolent between the tube and the lens could have things floating in it or maybe around the inside of the set around the mirrors. Im not sure if this is a model where the coolent went bad as it would get tiny peices floating in and around and they would grow in time so you had to pull each tube and drin the coolent take apart the tube and clean the tube and the lens . Then put everything back together with new coolent and realighn everything. Now older sets dont have the coolent so they have a space between the lens and the tube or a solid sheet of silicon that gets dried out sometimes as well. Anywho a picture of what it looks like would help if possible. Remember theres alot of voltage inside these sets so its not something a general handyman should be messing with as ive seen these sets make a grown man cry!!(including myself!)Good Luck
Posted on May 22, 2006
  • 513 Answers
It's hard to tell for certain, but from what you're describing this sounds like the degaussing mechanism of the TV is either malfunctioning, or that there's some electromagnetic field around that keeps screwing with your TV. This could be caused by speakers, lamps, or any other electrical device. In any case don't hurry to spend 400$ on repair, it's been only three days, and there's a nice chance its not the convergence, or that you'll be able to find someone in your area that won't overcharge you. If there was any device added to the mix around the TV lately, remove it, and try plugging out your TV over night. If turning it off and on a few times won't solve it in the long run(that's the way you make the degauss mechanism work), you should look again into repair options in your area. Good luck
  • yoav kleinfeld
    yoav kleinfeld May 22, 2006
    Could be good to get a second opinion on this, techman?
Yelloiw & blue lines outline characters causing a doubling affect
You have a bad convergence board. You will need to replace two convergence ICs and a few low ohm resistors.
Apr 11, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
Rear projection guns not alligned red and blue outlines on images
You will need to replace the convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305-DPTV345 convergence repair kit also works for your model. You can get the kit which also contains the CD with instructions from www.tvrepairworld.com
Dec 01, 2009 | Philips 43P8341 43" Rear Projection...
Wheni turn on my tv ive got a blue outline on what ever i whatch
The blue outline is a convergence problem. Depending on the brand of tv you have there are adjustments to fix that. If the adjustments wont work then the convergence circuit will have to be repaired.
May 04, 2009 | Philips 55PW9363 55" Rear Projection...
Philips big screen projection tv
sounds like the Convergence ICs are getting ready to go. Does it appear as a outline almost 3D? If so its convergence if its more like a glowing halo its coolant in the blue CRT that needs changing.
Jun 20, 2008 | Philips 51PW9363 51" Rear Projection...
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Your Convergence ICs need to be replaced. If you need anything further let me know.
Jan 23, 2008 | Zenith R40W46 40" Rear Projection...
Convergence problem
sounds like convergence amps bad
Oct 23, 2007 | JVC AV-56WP74 56" Rear Projection...
Color of the picture
Hi! henori,
This set is out of convergence. Go to your menu button on your remote, press it, then
find convergence and follow the directions for adjusting the convergence.
Toprol
Oct 15, 2007 | Philips 55PW9363 55" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
447 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
