Question about HP OfficeJet 6110 All-In-One InkJet Printer
Faxing multiple pages
I want to fax multiple pages, but I never get the option. It just faxes one sheet and then stops.
I'm not sure what I'm doing wrong. And my Realtime setting is switched to off.
I have been successfully faxing multiple pages on my HP 6110 All-in-One for a few years. About a month ago it stopped multiple-page faxing. The machine properly feeds all the pages through the document feeder. After it sends the first page, the display reads "Sending p. 2" and then it does nothing further. The phone line remains open but no more pages are sent. I then have to cancel the fax and send page 2 and each subsequent page as a separate fax. Any suggestions?
Thank you.
  • newtsmom Oct 10, 2008
    I am having the same problem
  • Anonymous Mar 18, 2009
    I have exactly the same problem
    Genius:
  • 1,605 Answers
Reinstall the printer software. deleted the existing printer software first.
Posted on Oct 10, 2008
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Upon incoming message, multiple sheets of paper
Switch the machine off,remove the document and plain paper tray,at the intake of the plain paper parth there is two gray rollers,Clean them with a strong soap sullution,just make sure the main board dont get wet.
Nov 19, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
How do i get my fax machine to print out confirmation with 1st page faxed
go into you fax options just look for conformation send or confirmation on fax error you sould be able to find those options in the general fax setup.
Oct 12, 2009 | Office Equipment & Supplies
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Keeps printing pg 1... sender's machine says it isn't going thru
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to reboot
Jan 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Open the document feeder (number panel). Make sure that a switch actuator is not stuck down.
Jun 03, 2008 | Brother IntelliFax-2820 Laser Fax
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
406 people viewed this question
Seeker5211
Seeker5211
