Question about Dryers
Im change the cordon the 3 to 4 line conection i need the combination please - max-
  • 943 Answers
Hi thanks for the question its red to red black to black white to white green to green thanks the appliance doc
Posted on Sep 13, 2008
Vw sharan radio proble
HI Youssef
i believe that when you put the volume up to the max, you blow up the main fuse, because the new radio with volume up to the max consume more amps than the fuse is set to for the original radio.
now you have to look into the fuse boxes and replace the fuse, this will sort out the radio and the door lock problems as i hope.
Good luck
Aug 17, 2014 | Volkswagen Sharan Cars & Trucks
What is the wattage breakdown for each speaker on my pair of Pioneer CS-N575 3 way speaker towers (I know the total max power combined output is 150 Watts)?
It's the woofer that will use almost all from this 150 W so if you replace woofer take one of 8 ohm which can handle 150 W and you done
Jul 15, 2014 | Pioneer Audio Players & Recorders
Resetting a kipling 3 digit lock
In order to set or re-set your Kipling lock, please follow these steps.
Step 1
Turn the dials to the preset combination and align the numbers to the Guide Line.
Step 2
Push the reset button with a pen (or other tools) all the way until complete turning the dials to your desired combination. (Do not let go of the button while setting the dials)
Step 3
Release the Reset Button after changing to your own combination. Your lock is now ready to open at its new combination
Jul 28, 2011 | Garden
Is there somebody speaking french ?
Oui je parle francais, quel est ta question?
Feb 15, 2011 | Office Equipment & Supplies
Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Jul 23, 2009 | Black & Decker Electronics - Others
Why is my modem not recognised by vista ???
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Tecra 8100
remove the battery, run it on ac power pack, for five min, then install battery while it's on.
Apr 18, 2008 | Toshiba Tecra 8100 Notebook
PS3 display settings
Check the owners manual for your TV to see what the max. resolution is and then confirm settings in ps3 menu
sounds like you have the right resolution but wrong type of signal (interlaced or progressive (eg. 480i, 480p))
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Kv27fs100
use the 6 and 9 vlts 600 ma. transpormer conect the 6 vlts AC to heater 1 and the common grn to heater 2 the primary conection use 10 W. bulb with riceptacle conect the one line of the bulb conect to G2 of screen board back of the tube and the other line to RGB first conect R the 10 W. bulb light blinking if the bulb light steady finish. conect to the G if the light steady conect to B. finish good luck god bless
Jul 29, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Dryers Logo
48 people viewed this question
Top Dryers Experts
