Question about Xerox Office Equipment & Supplies
I have a Xerox Phaser 6115mpf. I thought I was checking to see how much toner was left and I pushed the button with the colored dots. Which I now know is the change cartridge button. I opened up the machine and found the user's guide. It just says instructions are on the cartridge box. I cannot close the machine and I have no cartridge box. I'm pretty sure that the catridges are not out of ink. We have printed just over a **** of paper, most of which is black printed office type stuff. How do I proceed? Thanks myoug
  • 1,800 Answers
Unplugg/plug cartridge run alignement utility and see what happend if its not okay try clean the nozzels
best regards
plz rate this poste
Posted on Sep 13, 2008
  • 421 Answers
Http://office.manualsonline.com/manuals/mfg/xerox/6115mfp_d.html try this website you will need to set up a free membership but they have the complete user manuel and that will show you how to properly reinstall the toner please rate -jeff
    Genius:
  • 2,035 Answers
Well the instruction is on the cartridges which is printed back side of the toner cartridges.....Please use this link to get instruction to remove the cartridges from the printer :
http://download.support.xerox.com/pub/docs/6115MFP/userdocs/any-os/en/TonerCartridge075104500a.pdf
Good luck...
  • Xerox Master
  • 19,396 Answers
Do the following procedure.
Take off the cartridge that is inside.
Put the cartridge back in.
Unplug the power for ten minutes.
restart.
I
  • Ginko
    Ginko Sep 13, 2008
    If the machine does not close it also means that the toner cartridge is not well in place, pull it out and put it back.
4500 Phaser -What causes black dots left side of page?
Sounds like something stuck on a roller with a diameter of ~1/2" diameter.
Good luck.
Jun 10, 2014 | Xerox Phaser 4500 Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 6130: machine is about 2 months old,
Have you checked the Xerox support site? If not, try these links for your printer
Documentation
Drivers
Product Support
Troubleshooting
If this helps, click YES below.
Jun 30, 2009 | Xerox Phaser 6130 Laser Printer
Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
Just changed the black toner and now it won't print black.
Sometimes it may not be the toner that is the issue in this case the problem is with the black imaging unit, remove it and check for any damage and check the how life is left on it, if you have a spare then replace it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=49,E=0000000001347412543,K=9952,Sxi=0,Case=obj(4002)
copy and paste this directly into your address field!
Mar 31, 2009 | Xerox Phaser 6350DP Laser Printer
Toner not fusing to the page but fuser is ok
Try the steps on the link below. You can set it too a special paper, also check that there is not loose toner around the contact of the toner cartridges.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=609,E=0000000000024639304,K=4398,Sxi=10,Case=obj(79216)
Niallbt
Mar 26, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
99 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
