Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My machine doesn't wash
The wash doesn't start
  • 750 Answers
Hi twiggytrois,
You say,the wash doesn't start
Check the breaker that it is on and supplying power.
Check the outlet that it is getting power.
You can do this by putting an electric tester to the outlet or if it is a regular house hold outlet then you can try to check the supply with a lamp or cell phone charger to see that the outlet is good!
If these procedures do not find the problem you will need hands on service!
If the appliance is 10 years old or more you may not be advisable to
put good money into bad! New appliances are so much more efficient today
that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Sep 13, 2008
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
Starts water cycle then stops
Probably needs new carbon brushes in motor.
Dec 17, 2011 | Bosch Washing Machines
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
Key symbol coming up cannot do washing cycle
Try and hold down the Start button for 10-15 seconds, or until the key goes away. If this doesn't work for your washing machine, or your machine is not a Bosch, let me know the make and model and I will help you out.
Jun 14, 2011 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
