SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine
what's wrong with your LCD monitors. After you turned it on and the screen
blacked out or stopped working, you have to check that if you can see the image on the screen or
not by shining a flashlight into the screen, not directly but find the best
angle to the screen and take a look very closely. If you can see the icons or
any image, there will be a minor problem. This is because of the lamps inside
screen. Some of them were broken and it is very easy to replace. If you cannot
see anything on the screen, there'll be some problems with inverter board. If you
have soldering tool and want to fix it by yourself, check the caps first. It
may cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the
inverter(power plug). Parts that go are the backlight ccfl's, behind
the plate, and parts of the inverter, ie capacitors, all three take a
bit of power from the inverter. The self test check that all the lights
are ok and the inverter is ok, else it switchs off, ie if 3/4 light
work it will switch off(my own case), hence the on chech error then
off, However sometime there are stages of on/off ie on/ but no screen
display, if that is the case the following may be of help...if you put
bright light at an angle close to lcd can you see a windows shadow,
text icons etc, ie still logic power passing,then .... (from a.n.
other) after two weeks searching I finally find doctor living stone
http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with
paulbtorrent
the takening the case bit off is like opening your wallet a second time
after buying a new LCD, but you must! smallest two screw driver's flat
headed, practice using two pennies stuck together()with your fingers
after, one little () move and inch and {} again, with the case , it
does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip
inside!] also note the bright light test to do first to see if can see
a windows screen , and that capacitors are one for a number of things
that a make a inverter work! there a transistors as well, given that
however, to replace all the capacitors on my inverter, was 11
capacitors, cost me $11 (uk ebay) and already had the iron and solder.
So only cost me me $11 to try and see but no luck , still fun and I
still can see the screen for 2 sec' at a time plus I have a spare set
of caps now in the event that the new one do go burst! you have to
laugh really, what next , a new on/off button, as you work though the
whole inverter mmmMMMMmmmMMMMmmmMMMMTim
Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight
mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the
inverter. If it went out over a slow period of time (flickering etc..)
I would bet it is the lamp.replaceing the lamp should be pretty
challenging. as that requires complete breakdown of your LCD,
extraction of your dead lamp, and soldering in your new lamp... but I
would like to say that I it did this after realizing it's 2 x kitchen
strips inside [========] with wires that can connect back to the
inverter with out any desoldering(ie kit assembly/dis) with the outter
case remove (glass plate safe away) I could reconnect and see that 3/4
were working (i!i hardcard ) cause the inverter to switch off after a
secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a
1/3 of the price ! the market as drop out there, hope the inverter does
not miss the length, or the screen out
put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR
MONITOR
SOURCE: samsung syncmaster 920wm after a few seconds from
The
picture board on your monitor is bad, since it goes off after few
seconds and the power led or button is on, it means the
board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
