Question about GE Dishwashers
Dishwasher will not start this is washer is still under warranty
    Novelist:
  • 171 Answers
Hi megriffin1,
I'm Harvey the Master Plumber.
You want to know what to do if the d/w won't start?
You're on the right track but first lets check the breakers (fuses). If good then check the connection at the d/w. It's under the d/w behind the kick plate under a cover box. 9 times out of 10 you'll find a loose or burnt connection there. That done, it's time to call in warranty repair.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
How to fix a bosh dishwasher with E 01 code
The E01 error may mean that the water flow into the washer is restricted or that the flow meter is not reading correctly. Sometimes the control board near the washer inlet is faulty and can't read the signal from the flow meter or send that message to the control panel.
First check your shut-off for the dishwasher and make sure that it is open. Next turn the valve off and disconnect the inlet hose. Connect a new hose to the valve and position a bucket under the hose. Open the valve and check the water flow. If you have good water flow, try connecting this new hose to the inlet of the dishwasher. (Unplug the dishwasher. For an under-cabinet dishwasher, you'll need to pull the washer out. Make sure to keep the discharge hose from pulling loose. Then disconnect the old hose from the fitting and connect the new hose instead. Then slide the washer carefully back into place without pinching the hoses or cables.)
If you add a comment with the model number, I may be able to give more specific directions and replacement part information. Of course, if the dishwasher is under warranty, contact Bosch.
I hope this helps.
Apr 12, 2015 | Dishwashers
Help me
If you have water for washing the dishes and only the rinse water will not flow then the problem is likely a defective timer control. The timer send signals to the washer for all of its basic function to start and stop. Bad timers are a common problem, especially with an older machine, but they can also go bad in a new machine. f the dishwasher is under warranty follow the warranty service steps to get local free repair. Otherwise you may have to purchase and install a new timer yourself or hire someone to do this at an appliance shop.
Apr 29, 2013 | Dishwashers
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
Maytag dishwasher/two months old/packets that came with the dishwasher not disolving/on bottom of dishwasher??
Has this been a problem from the beginning? Is your hot water the correct temperature as specified in your manual? Please check this.
To check whether your dishwasher is heating water, please just feel the outside of the washer when running and notice whether there is steam after the cycle.
Usually one tab goes in the washer itself and a second one in the little dispenser in the door.
Your Dishwasher is still under warranty, so you need to call a Maytag repairman for help if these simple suggestions do not work.
Thank you for using FixYa. Please rate this solution
Dec 26, 2010 | Dishwashers
I have a bosch dishwasher and it is showing an E24 fault code. Any idears?
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Dec 09, 2010 | Dishwashers
The faceplate sometimes does not respond when I touch it, or if it does It may not let me cahgne the settings... Plus when the lights do come on the dishwasher won't start when I press the start button. ...
I also own a ADB1500AWB. The switch membrane failed within 30 days of purchase. It was replaced under warranty. The technician said this part fails very often. I bought an extended warranty.
It failed again on 9/3. As of 10/13, the part is still on back order.
In any case, buy the longest extended warranty possible. Good luck.
Sep 25, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
I have an MDB760 dishwahser making a lot of noise
The pump is not turned on when the what is sloshed around. It is the wash motor which turns the arms around. It is likely something is stuck under the washer arms or the washer motor bearing is faulty.
If the dishwasher is only about 2 years old, I would suggest you call Maytag for warranty service. Depending on the part they will have different warranty time period. Normally 2 years should be a general policy .
May 08, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
