Question about LG VX4400
Cell phone Why does my cell phone keep shutting off for no reason? The battery is fully charged.
  • zen love x May 11, 2010
    how does one go about reflashing one's phone?
    Brigadier General:
  • 7,752 Answers
The firmware may need to be reflash
Posted on Sep 13, 2008
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
Tip
How To Keep Your CellPhone's Battery Good
1- Don't Ever Let The Cell Phone Shut Down When It Have No Battery 2- Don't Use Your Cell Phone When It's Charging 3- When The Battery Is Fully Charged Remove The Charger To Save What Charged And Don't Leave It Charging A Lot Of Time After It Is Fully Charged 4- If Your Cell Phone Come With Two Batterys Use The Two Don't Use One And Ignore The Other That Makes It Last Shorter
on Oct 06, 2010 | Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Keeps shutting off
check ur battery................
Jul 23, 2012 | Samsung T301 Cell Phone
My motorola i1 (provided by boost/nextel) phone keeps shutting off & turning back on on its own. I have never dropped my phone nor got it wet. My battery is fully charged & it only shuts off &...
Try get another battery, it could be that the present battery you are using is malfunctioning, it could be bad and that could be the reason why it is shutting off and on, first, replace the battery to check the performance.
Jul 28, 2011 | Motorola Mobility i1 Smartphone
Keeps Shutting OFF (battery shows fully charged)
Have you tried to update the phone's software/firmware? You should be able to get the update software from Sony Ericsson website and follow the instruction. Hope it helps.
May 24, 2009 | Sony Ericsson TM506 Cell Phone
Nokia 3555b shuts off for no reason
CAUSE:The Nokia's problem of shutting off is a design flaw.The tension in the spring at the positive contact is too low to keep the battery in contact with the negative pole.
SOLUTION:Just  wedge a small piece of paper between the actual phone and the positive side of the battery(not between the contact) .This will prevent the battery from shifting away from the negative pole which causes the phone to shut off...
Hope this helps.
May 18, 2009 | Nokia 3555 Cellular Phone
LG VX4400 Logo
65 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
