Question about Refrigerators
MY LG REFRIGERATER
I HAVE A LG I DONT REALLY KNOW THE MODEL BUT IT HAS THE TO DOORS ON THE TOP AND THE PULL OUT FREZZER ON THE BOTTOM AND RIGHT NOW WE ARE TRYING TO FIGURE OUT WHAT IS WRONG WITH IT.
WE JUST RE DID OUR KITCHEN AND MY DAD WAS PUTTING TIEL ON THE FLOOR SO HE MOVED THE FRIGE TO GET THE BACK AND SINCE THEN I HASENT BEEN WORKING THE SAME.
HE THINKS ITS ONE OF THE FANS BUT WE DONT REALLY KNOW. IT MAKES THIS SORT OF ROARING SOUND WHEN WE CLOSE IT. AND THE ICE MAKER IS MAKING ICE BUT IT MELTS SO ITS ONE GIANT PIECE. AND NOW WE CONNECT IT THE THE SAME OUTLET WERE IT WAS BEFORE AND IT WILL WORK AND MARK THE TEMP. ON THE TOP BUT A MINUTE WILL GO BY AND I WILL STOP MARKING. WE HAVE NO IDEA WHAT TO DO!
WE TOOK OF A PANNEL FROM THE BACK AND WE DONT EVEN WANT TO TOUCH IT BECAUSE ITS NOTHING BUT WIRES!
PLEASE HELP!
ALI
  • 706 Answers
Hello ALI,
I am not sure I totally understand what is wrong with your refridgerator but I wil try to help you as best I can. First off, here is a link to an LG Website that you can get the Service Manual for your fridge once you've identified the model number. You should be able to find that on a tag inside the refridgerator compartment ( normally on the upper left side but it may be someplace else) Look inside the fridge on all panels and door openings for the tag and write down the model number. Then use this link http://136.166.4.200/SubPages/DA_Fridge.htm#Bottom%20Freezer to find your specific refridgerator. Once you have the web page for your model, you wil have options on the left side that will allow you to download the service manual.. and other useful information if you want it. Ok.. so that will get you started but I will ask you to try a few things.. When you pulled the refridgerator out for your remodeling project, did you run over anything that could have gotten inside the bottom of it? Please check there with a flashlight and make sure you don't have anything caught inside it... If I understand you correctly, you implied that you plugged the fridge back into the same outlet that had been working correctly... If the ice maker is making ice and that ice is melting, you may have damaged the one of the thermal sensors that monitors freezer temp .. There are many many things that may have been damaged but I would make sure that your water line coming into the back of the fridge is not pinched off and that all the doors seal ok with ther gaskets.. and there is nothing caught underneath. and above all.. your incoming power is OK. I'll check back again to see if any of these ideas ( or some that you may find in the service manual) may help.. Good luck..
Posted on Sep 13, 2008
I have lg french door refrigerator lfx21976st pull cold air but does not freeze in the freezer
Inspect back panel in the freezer section. Is it covered in frost?
Feb 01, 2015 | LG Refrigerators
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Replacing funnel/funnel frame on LG fridge model # LRSC26944TT
I am a year too late to help this person but also recently had to replace Funnel Frame on my LG Fridge model # LRSC26925SW. Literally just finished so sharing a quick tip. Not sure if it's same on all models but worth an easy shot. Tried the screw driver thing with no luck as it was just digging into the plastic even at the one little tab hole at bottom of the Frame... So instead, I stood to left of Fridge and cupped my hands around the edge of the door and into the left side of the curved part of the bezel (more towards the bottom) and simply pulled towards me and out away from door (almost like clamping my grip tighter) and the bottom portion popped open with enough gap to work the rest off gently by hand. Pull out from the bottom first and then slide the assembly down to release the top. Once you replace the funnel frame and are ready to reassemble, work the top of the Bezel with the display in first and slide upwards, you'll know when it's in the right place and then snap the remaining three sides a little at a time with the side of your hand (firmly if necessary). It didn't break any clips in case you are wondering... they are designed to release and clamp in that fashion... Ice dispenser now works as good as new... Funny part is all I "really" needed was the Funnel, but LG changed the part and it would only fit if I also replaced the Funnel Frame. Good Luck to the next person reading this!
Mike W
May 28, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Broken hose at the bottom of refrigerater door that feeds into
to remove door there are screws at top door hinge, them and door should lift right off. fold back gasket and you will find a lot of screws under gasket remove them and inner door panel should lift off exposing hoses .
Jan 26, 2009 | Refrigerators
LG wm1814cw washer is leaking from the front
Did you check the door bellow. I know you said it's not the door but if you really open that rubber pull it back and check it from top to bottom. let me know I'll keep thinking.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Lg washer model no wd 8013c door wont open tried everything and the child lock is disengaged
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
Jun 19, 2008 | LG Washing Machines
Asko dishwasher trips safety switch when turned on
dont know what model you have but check to see if theres a broken wire in the door right side bottom,check the element or the wax motor red right side top in door if your model has a drying fan.if this doesnt help i will need to know your model no
Apr 09, 2008 | Dishwashers
Need a handle for the freezer
heres the parrt number, although i dont really know who supplies the part, i guess you can call lg direct
3651JA1033C titanium handle for freezer door approx $40 US
Apr 07, 2008 | Refrigerators
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
