Question about Durabrand DWT2704 TV
No uhf channels
I can not get above channel 13...no uhf
    Scholar:
  • 146 Answers
Go into your tv menu. Find the area that you program the channels. Switch the type of signal from "cable" to "anntena" and then use autoprogram to reprogram the tv.
Posted on Nov 19, 2008
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
On olevia tv, channel scan will not pick up channels 3 to 13
i think the low band on your tuner has failed
Nov 16, 2014 | Olevia 332V LCD TV
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
RCA VCR VMT 385A support needed
c is cable
h is hi vhf (7-12)
l is lo vhf (2-6)
u is uhf (13 and up)
Dec 31, 2007 | Televison & Video
ONLY GETTING CHANNELS 2-13
If you are talking about the vcr menu you will have to scan or
enter the uhf or cable channels
Nov 14, 2007 | RCA F36645 TV
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
71 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
