Question about Averatec Computers & Internet
Avaretec 5400 Laptop will not hold CMOS settings. When you shut down the computer and restart it, it reverts to 2003. Any ideas how to fix this? Joe
  • maciolekjoe Sep 13, 2008
    How do I flash the bios? Is there something I need to download?
    Joe
  • 6,487 Answers
You need to flash or update the BIOS of your laptop that will fix this problem...
Hope that helps.............
Posted on Sep 13, 2008
  • Mark Gil
    Mark Gil Sep 13, 2008
    Yes you need to download the software for that , it will come from the manufacturer of your laptop..
My D 630 Win 7 laptop periodically resets time & date to the last manual setting? Is there a fix?
Not too difficult if your a member of the computer Dr mobile pc Dr's in black n white volkswagons. But it is the battery on the mother board
it should be 3.0 volt lithium watch battery 2016. Battery is dying an not holding its tsr programs on the cpu an reseting to defualt cmos
changing battery's information onyoutube based on your pc cabinet and its model and serial number. They'll play start to finish end user information on issues listed by steps
Aug 26, 2014 | Dell Computers & Internet
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
Got a dell latitude e6400series forgot bios password can i fix this problem ?
Welcome to Fixya
Common procedure in resetting the password is by resetting the motherboard by reseating the CMOS battery. You need to access you motherbard and locate the circular silver metallic object on the motherboard. This is much bigger in size compared to a wristwatch battery. CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. Put the the battery back in and turn on the computer.
Other procedure is the jumper reset. Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
If procedures above has been done and yet you are getting same results. Its time to call you manufacturer and have the motherboard re-flushed or re-imaged.
Thank you for using Fixya!
Mar 31, 2011 | Computers & Internet
Dell Latitude D620 BIOS password help!!! I bought a Dell D620 and I noticed that some BIOS features are password protected. The previous owner said he doesn't know anything about it, so I'm not sure what...
Dell usually sets a default password as password or admin Try those first. If no luck go into the bios setup by continually tapping the exc key while the computer boots. If your licky you may be able to set yourself as administrator and give yourself admin rights. With admin rights you can do anything.
Nov 11, 2010 | Dell Computers & Internet
I have an Averatec 5400 laptop. It will not hold its cmos settings. Everytime it boots up it reverts to January 2003 and I have to reset the settings. Any help would be appreciated.
You need to replace the CMOS battery. This will be under a "Flap" under the laptop. It is a small round thin Cell. 3.6 v similar to a Watch battery. link below to see what I mean. http://www.alllaptops.co.uk/Cmosbatt/Averatec.htm
Mar 12, 2010 | Computers & Internet
My new HP notebook won't turn on. I've had it for one month. There is a light on the side where it is plugged in, but it won't turn on
Unplug the AC adaptor. Remove the battery. Hold down the start button for 1 minute. Replace the battery and plug in the AC adapter. The computer should reboot.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Can not operate computer because I messed up the password at the beginning of start up. After 3 tries it shuts down. Can not get into startup to fix the problem. I there another way to get in?
open a side door of the computer take out the jumper and restart your computer it will set to default setting means no more passward problem then put it back by restarting it .. your computer will than not require passward.. thank u
Jun 25, 2009 | Toshiba Satellite A100-S8111TD Notebook
I am trying to reboot my acer laptop
have you tried configuring the BIOS to its default setting or setting it to its optimized default. and then restart. if still doesn't work out change the CMOS battery. if you need driver try this website  www.driver.com
Nov 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Avaratec 5400 Laptop willnot hold CMOS settings.It reverts to2003 when you reboot. Any ideas why and how to fix this? Joe
Need to change the battery on the motherboad. Any walgreens should have the one that you need. If you feel confident in opening your laptop then by all means, save $
http://answers.yahoo.com/question/index?qid=20080119191108AAJRSf1
Sep 13, 2008 | Averatec Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
