Back to:
Tags:
Gateway M305CRV PC Notebook
Gateway m305crv laptop (by 2 users)
posted by tourney on May 17, 2006
The image on the monitor screen is rotated 90 degrees. Can you provide a fix for this condition?
Thanks,
T
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 05, 2007
can i ask 4 the pcv diagram of the Lcd?
Best Solution
posted on Jun 27, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Do control, Alt, up arrow, that should reset the screen to its right side up position!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on gateway m305crv laptop:
I don't want to Accept this solution
Solution #2
posted on Mar 17, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
The laptop fell on my head and I don't know what it did lol but resolution rotated by 90 degrees. What I did was open Control panel, under hardware click on Tablet PC settings and change the orientation back tp primary landscape.
Thank You!
Solution #3
posted on May 22, 2006
FixYa! (100)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3302 votes
Usaully a rotate feature in included in the video cards options/features.
There are 2 ways I know of, but there's no way of telling if it will work with your video card:
1. under display properties, click settings, advanced, Intel
extreme Graphics, Graphics Properties, Rotation.
or
2. open display properties, click on advanced, Click on the
adapter tab, click on advanced, on a side menu, the rotate
option is there. I can set my display to all 4 rotation
options.
If you don't seem to have those options, upgrade or reinstall your video drivers from the manufacturers website. You can also do this through the same display properties menu.
Otherwise there should be some rotate software around, you could go hunt for it on download.com or google.
Good luck
Thank You!
Provided by TOSHIBA STAFF
Solution #4
posted on Jan 29, 2008
Not Rated (0)
AvioriX
STAFF
Rank:Guru Guru
Rating: 91%, 377 votes
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Thank You!
Solution #5
posted on Dec 31, 2007
Not Rated (0)
Schmoozer
Rating: 85%, 1 votes
You can also try holding Ctrl and then pressing one of the arrow keys.
Generally:
Ctrl+Up is normal
Ctrl+Down is upside-down
Ctrl+Left is bottom to the right
Ctrl+Right is bottom to the left
But as said previously it depends on what type of video card you have.
Thank You!
Solution #6
posted on Nov 06, 2007
Not Rated (0)
crane
Rating: 0%, 0 votes
try pressing ctrl+alt+up(arrow key)
Thank You!
Solution #7
posted on Aug 22, 2007
Not Rated (0)
ServerMonkey
Rating: 0%, 0 votes
Perfect, thanks!
Thank You!
Solution #8
posted on Jul 26, 2007
Not Rated (0)
polofly
Rating: 0%, 0 votes
u can do by pressing ctrl+alt+down button
Thank You!
Solution #9
posted on Jun 23, 2007
Not Rated (0)
RFro
Rank:Guide Guide
Rating: 94%, 39 votes
Try holding CTRL + ALT and hitting the up arrow.
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
my gateway laptop boots up, but it has a black screen. i...
I power up the laptop and the only thing happens is the...
I have a connection to the SVG socket on my laptop and I...
My ubuntu program will not recognize my wireless card by...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
