Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Washer won't spin
White westinghouse washer 2 years old. when gets to spin cycle, just stops. fills, washes and agitates fine..just wont spin or drain.
  • 2 more comments
  • Anonymous Dec 01, 2008
    same problem wwx433rfs0
  • Anonymous Jan 24, 2009
    how to change belt
  • Anonymous Mar 14, 2014
    Washer wont agitate and noisy spin cycle
  • Anonymous Mar 15, 2014
    washer agitates slowly or not at all. It fill and spin fine.
    Genius:
  • 1,028 Answers
Press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Posted on Sep 13, 2008
4 Suggested Answers
  • 686 Answers
SOURCE: Washer fills, agitates in wash cycle, then stops.
you need a new timer
Posted on Apr 06, 2009
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
White-Westinghouse wash cycle not engaging
Likely transmission failure. The motor controls agitation as well as draining
Feb 26, 2013 | Washing Machines
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
20 year old front load white westinghouse washer goes into spin cycle when knob is pointing to wash cycle
20 years old? And you expect it to still be working?!? You can't even get parts for it anymore.
Oct 19, 2009 | Westinghouse Washing Machines
Washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Won't agitate or spin
Try to replace lid lock which is located below the top cover
Feb 10, 2008 | Washing Machines
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
1,250 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
