Question about RCA F36673ET 36" TV
Possible power supply problem?
RCA F36673ET 36" TV The picture and sound cut off while watching it and there was a very high pitched whining sound coming from the back where the power cord goes in, when I unplugged it, the sound 'faded', the only other way i know to describe the sound is that of a jet engine slowing down to a stop, if that makes sense. If I plug it back in, the sound starts again and fades when I unplug it. Any ideas? Thanks.
    President:
  • 3,130 Answers
Yep i can tell you what it is. The High pitched sound is the power supply soound when its overloaded and thats because the Horizontal output transistors shorted and this happened because of the flyback transformer went bad and /or the horizontal driver coil right off the secondary of the horizontal driver transformer and then the other side of this coil connects to the base of the horizontal output transistor. The part transformer cost about 35 to 45 bucks to the dealer and the transistor cost about 15 bucks. the total repair job cost about 175 to 225.00 after all said and done and some shops even may charge more ad there labopr rates may be higher. Good Luck
Posted on May 17, 2006
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
I have a RCA projection TV. The picture and sound are fine. After the TV is on for a bit it starts a highe pitch whistle. The picture and sound continue to be fine. What is the problem and what can I do to...
Most likely the color wheel is starting to go bad adn when they do they get a high pitched whine sound coming from the bearrings on the wheel. Might want to look at getting a replacement before it quits. When they die you can't watch your tv till it is repaired.
thanks
Jul 22, 2011 | Televison & Video
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
My TV shut off and will not come on
This is an issue with one of your power supplys wether it be high voltage horizontal power supply or the reg power supply. The beeping noise is letting you know that it has some power but not enough to start the high voltage needed to create the picture on your tube. I would seek professional help for this issue.
Nov 03, 2007 | RCA F36668 36" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Televison & Video Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
