Casio Exilim EX-Z57 Digital Camera
Problem for Casio Exilim EX-Z57 Digital Camera
Lens error
By rainey on May 17, 2006
when i go to turn on my camera it says "lens error" on the screen and wont turn on
Same Problem
Apr 19, 2009
-   I have a nikon coolpix 4100. I get the message Lens Error. Please help me in fixing this.-   pamela22
May 29, 2008
-   same as the question-   emily1993
May 01, 2008
-   i have the nikon coolpix 8700 and every time I turn on a display come saying lens error what can I do?-   rickya1
May 01, 2008
-   i have the nikon coolpix8700 and every time I turn on it keep displaying lens error what should I do?-   rickya1
Mar 22, 2008
-   when i turn on my camera it says lens error-   Guest
Best Solution
posted on Nov 16, 2007
Very Helpful)
jimsimm
Rank: Apprentice
Rating: 99%, 9 votes
Same thing happened to mine. I sent it back to Canon for warranty service (I just bought it in June) but they wanted $104 to refurbish the exterior of the camera because it was "scuffed and scratched." They contended that if the exterior is not in factory condition, it must be reconditioned to honor the warranty. Well anyway, I told them no thanks (not quite so politely). I just got it back in the mail yesterday and followed the advice of others I found on the 'net. As it's starting up after pressing the power button, a moderately hard whack on the table top (the bottom of the camera, the end where the battery goes) fixed the problem immediately. I'm hoping this will last for a while.
Other suggestions to prevent this, I've found, said to periodically blow canned air around the lens to dislodge any dirt particle. Also, do not shut off or turn on in rapid sequence. Make sure that the lens is fully retracted after shutting off before you say, ooops I forgot to get one more shot, and turn it back on. Apparantly switching direction of the retractable lens in mid stream can cause it to jam up.
Good luck.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on May 18, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3606 votes
Very common.
The casios have 3 ways to turn them on. apart from the primary button there's the rec and play button, and they tend to get pressed when people carry the camera ina restricted space, such as a pocket.
The lens then tries to extend, and when the camera senses that the lens is obstructed it triggers the error which is meant to protect the lens frmo damage.
What probably happens on many units is that once the error is triggered, there's no going back. while the error is supposed to clear next time you turn on the camera, a fault causes it to be imoperable.
To prevent this you must disable the option of having the rec/play button turn on the camera, which is possible through the menu, or/and have a good case to protect the camera.
You might be able to fix this with a firmware upgrade from casio, unfortunately there isn't any upgrade to this model on the casio web site. I suggest you contact them, and demand this to be treated as a factory fault.
here's the page it should be on, if you feel like waiting for it - http://world.casio.com/qv/download/en/
Good luck
Was this helpful?
Yes
No
Solution #3
posted on Oct 15, 2007
Somewhat Helpful)
deepkaur
Rank: Apprentice
Rating: 78%, 31 votes
i have a nikon coolpix L3 digital camera and i am having a lens error problem ,when i turn on the camera it shows lens error and doesn't turn on please solve this problem as soon as possible.
thank you
Was this helpful?
Yes
No
Solution #4
posted on Oct 04, 2007
Somewhat Helpful)
phluidphox
Rank: Apprentice
Rating: 72%, 10 votes
Just found this out via experimentation. Press and hold the power button for 15 seconds or more and it will cause the camera lens to go through the full range of motion and as a result recalibrate it and bring the gear system back to zero as it were. A grinding noise might be heard but its only the gears in the lens system skipping cogs. This will not delete the data on any removable media that you might have in the camera. I hope this fixes your problem.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Dec 27, 2007
Very Helpful)
huss huss
Rank: Apprentice
Rating: 100%, 1 votes
my camera is a casio exilim EX-Z75 when i turn it on it says lens error and i can only look at my pictures that i already took please help me so i can take pictures again!!!!!!!!!!
Was this helpful?
Yes
No
Solution #6
posted on Sep 07, 2009
Helpful)
cojy_cojy
Rank: Apprentice
Rating: 88%, 2 votes
just try to charge the battery... in my case it worked. maybe the camera stayed in my bag and it was turned on and off without my knowledge, so the battery got empty. i charged it and now the lenses pop out again :)
Was this helpful?
Yes
No
Solution #7
posted on Oct 04, 2009
Somewhat Helpful)
j1990r
Rank: Apprentice
Rating: 75%, 1 votes
lens shutter wont close and system error keeps flashing
Was this helpful?
Yes
No
Solution #8
posted on Jan 25, 2009
Somewhat Helpful)
Ziofimo
Rank: Apprentice
I have a nikon coolpix L2 very similar to L3 and other same series,
the cause of error is the flat cable that drives the step by step engine of lens , in my case it has broken a track that carries the signal from the home position sensor of the lens, I managed to repair it but the repair work has only just time and it is almost impossible without a microscope, the most practical solution is to change the lens, unfortunately it can only make the service center, because the spare part is impossible to find on the Internet and the service center does not sell this part separately
Was this helpful?
Yes
No
Solution #9
posted on Apr 06, 2008
Somewhat Helpful)
mayas
Rank: Guide
Rating: 79%, 8 votes
just sell it on ebay!
Was this helpful?
Yes
No
Solution #10
posted on Jul 12, 2009
Not Rated)
ismailmkl
Rank: Apprentice
Rating: 0%, 0 votes
How to fix an old video recorder sony handycam video 8, which cannot recording more than 3 min and it will eject the tape by it self.
Was this helpful?
Yes
No
Popular Solutions for Casio Exilim EX-Z57 Digital
Questions and Unsolved Problems for Casio Exilim EX-Z57 Digital
Do you recommend Casio Exilim EX-Z57 Digital Camera?
Answer
Answer
I have the Casio Exilim Optical. I dropped the camera while taking a picture and now the lens is... (More)
Answer
Elke keer als ik de camera Aanzet moet ik alle instellingen opnieuw doen die normaal alleen bij... (More)
Answer
When I turn the camera on I get a LENS ERROR message. CASIO EXILIM EX-Z57
Answer
my camera ex-z57 does not work, or respond to any command. I already charged it and then took its... (More)
Answer
goes to the menu and restarts itself everytime it turns off
20 Other Users Have The Same Problem - Continued
Comment by MWray, posted on Jan 02, 2008
I got my Daughter a Coolpix L10 for christmas of 07 she has only had it a week and its already saying lens error i thought i was getting a good camera but i think all i got was a piece if sh@@ i am very disappointed.We had turned it off and back on and changed the batteries it still didn't work think god i bought a three year warranty i hope they will be able to help
Comment by jrizzo8445, posted on Dec 30, 2007
When I turn on my EX S-600 camera the lens extends out then retracts again into the body and I get the message "Lens Error". Is there a solution to this problem or is factory service the only repair option?
Comment by hanban, posted on Dec 26, 2007
when i turn on my camera and set it to take a picture it says lens error and turns off, what do i do ?
Comment by Guest, posted on Dec 25, 2007
Yes have the same problem what's the answer
Comment by kchappo, posted on Dec 21, 2007
doh. lens won't open...suggestions?
Comment by tasha88, posted on Dec 09, 2007
when i turn my camera on it says lens error and won't let me do anything else with it!
Comment by Guest, posted on Dec 06, 2007
Lens jammed open
Comment by joanmay, posted on Dec 01, 2007
My Pentax Optio 60 shows 'lens error' and won't stay turned on. It is kept in a soft camera case.
Comment by mangilizi78, posted on Nov 27, 2007
my camera pentax optio show the lens error..please assist me
Comment by Guest, posted on Nov 21, 2007
i have a casio exilim EX-Z50 and whenever i turn it on , it just turns off by itself and it says lens error on the screen
what do i doo ?!
please helppp.
Comment by Guest, posted on Nov 17, 2007
when turning the camera on we get a lens error message and the camera won't progress to any other functions.
Comment by Guest, posted on Nov 14, 2007
lens error
Comment by cyndya, posted on Nov 09, 2007
The lens will no longer open. I suspect it must have been jammed while in a pocket trying to open. I can no longer use this camera and it was out of warranty when the problem occurred.
Comment by Guest, posted on Nov 05, 2007
my camera is casio exilim zoom ex-z60 digital camera it has a lens problem is says try power button and when i turn it on it says "lens problem" what can I DO??
Comment by Guest, posted on Nov 04, 2007
sd900 lens error. Tried turning on and off several times. clicking noise twice then camera tells me lens error restart camera. help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio Exilim EX-Z57 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
