Question about Juster DHT-918C Computer Speakers
Speakers When I turn my speakers on it makes what sounds like a synthesised buzzing noise, then quiets off a little to a medium volume buzzing. The Volme the speakers are set to has no effect. I have tried disconecting the system from the computer and that has no effect. It stops when I unplug the speakers or turn off the power. Thanks, Jeff
    President:
  • 3,130 Answers
If this happens when its not connected to the puter or any input or at any volume then its the capacitors in the power supply are drying up. You need to replace them. Good luck
Posted on May 17, 2006
Sylvania 7" netbook speakers have a loud buzzing
You may have to re-flash your system as the sound driver is inoperative. You can check at www.digital gadgets.com or follow my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Mar 22, 2011 | Sylvania G-Netbook
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
My speakers are currently turned on, at normal volume. Whether I try to play music or not, a buzzing noise comes from the speakers.
your power supply is bad for the speakers giving them to much power or there bad speakers plug some headphones up and see if it makes the buzzing if it does then you have a power problem with your computer or sound card
Mar 17, 2010 | Audio Players & Recorders
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
No sound from speakers
first you need to your name brand of your computer and you could go to the website who make your machine and you click support and you could download a sound driver for your pc
Dec 01, 2008 | Audio Players & Recorders
Computer speakers make a fuzzy sound
Hello there
Yes, Niera, you have to update, the sound drivers, and see on BIOS if something is disable on sound. other than that is posible a a speaker problem.
Jan 13, 2008 | Audio Players & Recorders
Speakers make a buzzing noise but wont play anything else
make sure that your system volume is turned up and that the speakers are turned all the way to the right.
Aug 22, 2007 | Dell A215 Computer Speakers
Juster DHT-918C Computer Speakers Logo
132 people viewed this question
Top Juster Audio Players & Recorders Experts
Victorman
Victorman
 Mike M
Mike M
Vladimir Frolov
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
