Question about Kenmore Microwave Ovens
Kenmore microwave - code F6 on screen
Appears to be model 60612 from 2000 - code appeared when shutting off and now all buttons beep but nothing changes nor removes code.
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Then let us know if the hard reset does not fix it, but please reply back with your full model number so we can help you.
    A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
4 Suggested Answers
  • 18 Answers
SOURCE: Microwave repair
Just google the Kenmoore website, put in your model number and it will tell you the error codes and faults
Posted on Jul 10, 2007
MicrowaveSvc
  • 8862 Answers
SOURCE: error code F6
Please post back with your your full model number. It will be three digits, then a dot, then about eight more digits.
Once we have that, we can figure out who made it for Kenmore, then look up the F6 code.
Happy to help.
Posted on Dec 05, 2007
  • 25 Answers
SOURCE: microwave KENMORE code error F6
F6 is a relay failure
Posted on Jan 14, 2009
SOURCE: Disabling the beep on a Kenmore microwave
Press and hold the "2" button for 5 seconds. It should beep twice when sounds are turned off or back on.
Posted on Mar 07, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
I have a Kenmore microwave and it is flashing F 6 on the screen. What does that mean?
Depending upon which make and model you have, F6 is the code for either relay failure or shorted temperature probe.
please rate oure helpfulness++++Thanks for usdng FIXYA
Sep 23, 2009 | Kenmore Microwave Ovens
Error code F65
That's what I thought, but I wanted to be sure.
F6 is a failure of the cook relay on the main control board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 04, 2008 | Kenmore 60654 Microwave Oven
What does -F6- code stand for?
F6 means a problem in the control circuit board.
Try unplugging the microwave with the door open, then plug it back.
Try the solution that you find here, if it does not work the panel must be replaced.
Sep 10, 2008 | Kenmore 63652 Microwave Oven
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Error code F6
Happy to help.
Dec 04, 2007 | Microwave Ovens
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
