Question about Stanley Proto Electronics - Others
I just bought a Stanley 500 watt power converter, and it only works intermittently. The green light starts blinking and power is lost to the device I have plugged in. I have to turn it off, wait a few seconds and turn it back on to get any power through it. The longest it goes without shutting off is about half an hour.
    New Friend:
    Problem Solver:
  • 8 Answers
Since it's a 500 watt converter, it can probably only put out 500 watts intermittently. As stated above, make sure the load you have is less than the continuous output of the converter, or it'll over heat. Also, make sure the input power supply is capable of supplying enough current and voltage to handle the load of the converter.
Posted on Dec 15, 2017
    Champion:
  • 219 Answers
How much is your device drawing ? Does it get hot ? Sounds like a Thermal Shutdown. Does it run nicely when nothing is plugged in ? Be careful with inductive loads, these babies hate them (motors and such)...
Posted on Dec 13, 2017
SOURCE: Flashing green light
sounds like the bulb is blown. Its the main lamp in the side of the set. you will see a small door there once you take it off there is 2 screws to remove and bulb in its casing will slip out. by looking at the buld you should be able to see if its blown. You should get approx 3000 to 4000 hours from a bulb but if you are a heavy user of this tv with higher contrast the bulbs dont last. i have this model tv myself and ive been told that they are not designed to be run for long periods of time and dont use gaming machines on them. Shame they dont tell us this when we are buying them.. hope this helps you Craig (crazy@woosh.co.nz) let me know how you get on
Posted on Feb 25, 2008
  • 53 Answers
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Posted on Mar 14, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 2336 Answers
SOURCE: Sony KDF-50WE655 won't turn on.
if your TV blinks 10 times. Possible solution should be to check and replace on the G1 board Q1600 and Q1601 if shorted and R1614 and diode D1605 open.
Posted on Oct 20, 2008
ladywinn
  • 5138 Answers
SOURCE: Screen keeps going black, green light blinks, then screen returns
Lamp- Mats has them 1-800-628-1118
Posted on May 29, 2010
Stanley power station manual
Can you get replacement cords for the jump starting part of this unit? The original ones on this are frayed.
Mar 24, 2013 | Stanley PPRH5 450 Amp Rhino Power Station...
What can i run with a 500 watt stanley converter
Assuming the output is 120VAC, you can only run items pulling about 4 amps. If the voltage output is 220 VAC, you can only run items pulling about 2.25 amps. Read the labels on the devices you want to use, they should list either watts or amps used.
To convert amps to watts: Current times voltage
To convert watts to amps: Watts divided by voltage
Dec 04, 2012 | Electronics - Others
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Will the 500 watt charge camera batteries
it depends on what type of batteries you are talking about. If they are batteries that are charged in a AA type that uses 120 volts then it will work.
Feb 23, 2011 | Stanley PC509 500 Watt Inverter
I just bought a 800 watt converter, installed the battery connection wires and connected it to a marine deep cycle battery and the LCD window displays 0 W which in the guide indicates an overload or short...
It says 0 watts because there is no load on the inverter! Plug something in, like a 100W light, and you will see the display go to something near 100W. I don't think you have a problem, other, like most of us, we don't completely understand Chinglish. Good luck.
Jan 09, 2018 | Stanley PC809 Inverter
I bought A Stanley 450 jump start & I'm to charge it for 24hr. The 2 red lights are on but the green light is still blinking after 14hr. What does the blinking light mean?
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
http://www.baccusglobal.com/faq.php
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Dec 05, 2010 | Black & Decker Jump Start System 450 Amp...
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Drive stopped working
    I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
    Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
    Electronics - Others Logo
    240 people viewed this question
    Top Stanley Proto Electronics - Others Experts
    Are you a Stanley Proto Electronics - Other Expert? Answer questions, earn points and help others
