Question about Kenwood KAC-X501F Car Audio Amplifier
Blown Amp Whilst wiring my stereo in i touched the earth and live onto the live and blew part of the gold leaf connection inside. is this repairable?
  • Anonymous Jun 15, 2008
    when i was wiring my amp i put the ground in the battery input and the battery wire in the ground input. No Fuses blew but the amp wil not power up or even show it is getting power but the battery wire has a current Can i fix this or do i need a new amp?
  • snipersmoke Jul 24, 2008
    i was thumping down the road and all of a sudden it stop playing and the red light came on.There was nothing touching and i don't see how it was blown or what ever so could i please get some feed back on this....
Be specific I've been repairing amps for 20 years I would like to help all I can, Amps have power supply problems, and output problems, these are the hardest worked parts. Who wants to learn to repair, I can show the way.
Posted on Aug 26, 2008
  • 215 Answers
It's a Kenwood so there's a good chance you've also blown a fuse for that channel. They may be inboard somewhere on the circuit board or they could be fitted somewhere accessable from the outside of the case. You may have to replace it if it's blown. Ensure you use the same type and amperage when you replace it and if it blows again it will mean a major problem further down the line. You'll also have to replace that burnt out track as you;'ve already been told. BMW
Posted on May 18, 2006
    President:
  • 3,130 Answers
If your talking about the printed curcuit trace on the printed curcuit board?? yea you can repair that by jumping the trace with a wire but if its for the b+,it has to be a BIG wire. IOf your talking about the terminal itself yes you can fix that too by wiring dirctly but its always better to contact the manufacturer and get a new terminal. Good Luck. PS see if this helps. 1-800-KENWOOD
Posted on May 17, 2006
2003 dodge neon keeps blowing ac clutch fuse
check the wire from the ac clutch back and look for a dead short to earth . look for pinched wire. Wire worn by drive belt etc. Any indication of where a live wire is touching earth.
Apr 20, 2013 | Dodge Cars & Trucks
Touching the needle arm causes sever feedback. Only half<?>of song is audible. Wires crossed?
Yes and not connected. Remove the wires and start again. Remember two of the wires are earth's and the other two left and right. You can identify the R & L by touching each wire with your finger, whilst the unit is on. The channel wires will buzz!
Aug 02, 2011 | Crosley CR248 Turntable
When car is hooked up I get visuals, lights. etc. but no sound transmits from the stereo to speakers. I have checked all speaker connections and RCA jacks, along w/ amp and subwoofer and all are connected...
The illumination wires (orange, not yellow. Yellow is for 12 volt in) would not have an effect on sound. Either the internal amp is blown or you have a shorted speaker which is preventing the internal amp from turning on. Disconnect all speakers and hook a KNOWN GOOD one to an output. I f you get sound, the problem is in the car, if not, the problem is in the radio. If you accidentally crossed two of the speaker wires or let one touch a chassis ground, you blew the amp.
Jul 01, 2011 | Car Audio & Video
I have a B&K power amplifier(home not auto). The original two wire power cord is damaged. I want to replace it with a three wire(positive, negative, ground) Originally one wire went to a fuse and the...
get an electrical tester (screw driver with live indicator built in) and check which socket on your wall is live, connect the live/phase line to the fuse and the neutral to the other plug-in wire connector. conect earth or ground to any part of the power amp housing (should be conductive). do not connect earth to any part of the circuit board. urs is an amp that is not built to have earth connection on the board. be careful.
Jun 04, 2010 | Audio Players & Recorders
Wont play while im driving
hi, the problem with these dvd players is they have a safety feature that is connected to the parking brake and this means once the parking brake is taken off the dvd player then will stop.
PLEASE READ THIS.
you do this at your own risk keep reading and ill tell you how to best go about doing what you want, if you get caught using dvd whilst driving you will get a big fine and points on your license ok
Its not advised you use the dvd player whilst driving so i cant reccomend you doing any work to it yourself.
If say you wanted it working whilst driving so that a passenger could watch it then their is a way around getting this working whilst driving, if you get caught using this whilst driving you will get a fine and possible points on your license as your not supposed to have any working dvd in the front of the car whilst moving as you will get distracted.
Now the problem you have of getting this working whilst driving is that your going to need to get hold of the instructions that was used to fit the stereo as this will then tell you witch wire is connected to the parking brake once you have this you then need to bypass this wire by either earthing it out if its an earth wire or if its a possitive wire then you would need to wire this into a permanent live feed like the direct live feed into the stereo.
Now you could take the stereo out and see where all the wires go to doing this would then show you witch wire goes to the parking brake you would then need to test this wire to find out if its an earth or live type of wire, to do this you would need to get hold of a multimeter one of these will tell you if its a live or not.
If you find the wire thats connected to the parking brake you should be able to tell if its live or earth by looking at how its connected to the parking brake if its just earthed out then it will be an earth but if it goes to a switch on the parking brake then its more than likely a live wire.
On asking someone about your make and model of stereo it seems the parking brake wire is a brown wire and you then need to remove this wire from the parking brake and just earth it out on any part of the metal of your car this should then let you watch dvd whilst driving.
remember you do this at your own risk its not advisable to use a dvd whilst driving and you are breaking the law by doing this so i cant encourage you to go ahead with this type of work, if you really want to do this then take your time and double check you have the wires correct ok
its not worth taking the risk by just guessing as this could blow your stereo up leaving it scrap so its best this wire is tested.
If you are unsure what you are doing then please dont mess with it as any short will destroy the stereo and it has been known to cause several car fires so if it is a live make sure you use an in line fuse.
It would be a lot safer if you went to the makers web site and see if they have an instruction manual on their if they havent then they will send you one out for free this would be the best option for you.
If you really are unsure and have never wires stereos in before then leave it to someone who knows what their doing they may question why you want it working whilst driving but just tell them you drive a kid around who watches it to stop him being car sick, the sob story usually works
Let me know how you get on or if you need further assistance
Mar 03, 2010 | Pyle PLTS76U Car DVD Player
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
Led light turns red and the turns off but the amp
In Car Amplifiers have 3 main power wires:
Live +12v (Fused wire direct from the + side of the cars battery)
Ground (Direct to car earthing point (anywhere cleaned of paint for good connection)(I tend to use boot lock)
Remote (This wire should be connected with the switched live wire coming from the back of the stereo, this is Only live when the cars ignition is on)(there should be 2 power wires coming from the stereo usually red live +12v and yellow switched live, depending on the cars original wiring, try moving the remote wire from where you have it, to the other live wire
Hope this is of some help
Aaron
Aug 08, 2009 | Nitro BMW-482 Car Audio Amplifier
My in-dash won't come on
yellow lead on car stereo should be going to a permanent live on car stereo wiring loom, (always 12 volts regardless of key being in or out) red lead on car stereo should be going to aux in car stereo wiring loom, (12 volts only when key in and ignition lights on) green lead on car stereo goes to earth to allow you to watch dvds whilst driving (highly illigal whilst driving!) read the manual, if this doesnt work fuse in car possibly gone?
May 10, 2009 | Car Audio & Video
No sound coming out
I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Aug 07, 2007 | Jl Audio E2150 Car Audio Amplifier
No power
Check the unit for any Fuses, Fusable Links etc, if they are OK proceede on to testing, I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with a Sinal feed in & the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Aug 03, 2007 | Legacy Audio American Legacy II LA290 Car...
Kenwood KAC-X501F Car Audio Amplifier Logo
1,492 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
