Question about Kenmore 63012 Electric Dryer
Putting dryer back together
I took dryer apart to replace blower wheel and now i can not figure out how belt goes back on
  • john gagnon
    john gagnon May 11, 2010
    Hi i need the make & model thanks THE APPLIANCE DOC
    Genius:
  • 1,028 Answers
From front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Posted on Sep 13, 2008
How do you get inside a Neptune Dryer. and then i have to figure out why the dryer is not heating?
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel (which comes apart for testing thermal fuse) to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How do you put the belt back on? It was making a screeching sound so I took it apart and now cannot figure out to get the belt tight. I have it back on and back together but do not know how to get the...
you have to open back panel of dryer as well as the top. there will be a spring connected to the motor assembly. unlatch it, check your belt to see if it needs to be replaced. if cracked, replace. latch spring and belt should have tension.
Oct 25, 2010 | GE DWSR463EG Electric Dryer
I have the model AWZ 7813 and the belt broke. I took the unit apart but need a new belt and the manual to show me how the belt goes on.
If you have seen belts in cars, there is something to remove the slack (spring loaded). Its similar to dryers,, the dryer belt goes around the drum and the motor (obviously). from there, there is a wheel that connects to the base. It is spring loaded and takes the slack off the belt. If YOU took it apart (recently), hold the wheel/spring assembly in your hands as it would be positioned if it were screwed into the chassis. Move the wheel to get an idea what direction the spring pulls.
I hope this helped a little.
Feb 27, 2010 | Whirlpool Dryers
Blower wheel is slipping off and it hits the metal and is really loud. took it apart because we thought the belt was broke but the belt is fine. i noticed that the plastic fan looking peice in fron of the...
the blower wheel should have a clamp on it you can buy this from your local spare parts department if not a small hose clamp will do the trick hope this helps.
Feb 01, 2010 | GE Profile Wizard DPSE592EAWW Electric...
How do I replace a dryer belt on Kenmore dryer
You have to practically completely disassemble the dryer and remove the drum. If you can't figure it out, you should call an expert. Sometimes getting it apart isn't bad, it's putting it all back together that gets you. ;-)
Dec 27, 2009 | Kenmore Dryers
Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Nov 02, 2009 | Kenmore 62602 Electric Dryer
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Horrible noise and burning smell when dryer is on
Same thing happened to us, the noise is one of your wheel bearings are going bad, (they are just a small piece of plastic rollers) and the smell is your belt. The dryer is dismantled from the front. I figured out how to take my dryer apart from google. Also, you may need some help to pull out the drum wheel and pay attention to how it came out. I ordered parts from repairclinic.com and it was very inexpensive and the parts took 3 days to come to me ( I wouldn't pay for faster shipping).
Good luck, you won't believe how uncomplex your dryer really is.
Jun 06, 2009 | Kenmore 62602 Electric Dryer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 63012 Electric Dryer Logo
116 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
