Question about Panasonic Televison & Video
My new panasonic projector pt-ae2000u won't project. I turn the power on and no light is projected...then the projector turns itself. This is with or without a dvd player connected.
  • 19 Answers
SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
Posted on Oct 30, 2007
Slinteriors
  • 8617 Answers
SOURCE: power up
is it a constant blink, or does it blink a nummber of times in between payses? Let me know the number of blinks. Please respond to this same post so I have access to previously posted info.
Posted on Jul 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Posted on Oct 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Posted on Aug 14, 2009
welcomejee
  • 10594 Answers
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Posted on Apr 18, 2010
Testimonial: "Thanks"
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
I have an panasonic pt-ae2000e projector, how do i get sound?
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Mar 21, 2011 | Panasonic PT-AE2000U Projector
Pt-ax200u projector turns off after 1 min of operation. the light turns red then green. After that, the power button does not respond and i have to cycle off the project. If I turn it on, it does the same...
your projector is detecting it is overheating, check that nothing is blocking the vents and that the fans are not clogged. If the vents and fans are dirty clean thema paintbrush and hoover. If they arent then the lamp maybe the culprit
Mar 07, 2011 | Panasonic PT-AX200U Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Dec 28, 2008 | Panasonic PT-AE2000U Projector
TV will not turn back on
had the same problem, I am pretty sure it's the projector bulb is burned out. easy to replace yourself
Jun 04, 2008 | Panasonic PT-53X54 53" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
