Car Audio and Video Accessories
Problem for Car Audio and Video Accessories
Generic problem for all Car Audio and Video Acc...
Stereo Power on but no audio
By kiyt14 on Sep 13, 2008
Hi, I forgot to include, maybe a key component to my past problem i wrote to you about before. Not only does the audio stop working, but the "chimes you hear when you leave the lights on or keys in the ignition" they don't ring anymore since the audio went out in the stereo. I don't know if this component makes a difference in the solution. I don't know how they are related. Please help fix this problem, I'm ready to pull my hair out about this, plus i don't want to end up with a dead battery or worse yet-lock my keys in the car.
Thank you for all the time you have taken on this.
Kimsu
Solution #1
posted on Sep 13, 2008
Somewhat Helpful)
keemo68
Rank: Guru
Rating: 87%, 1030 votes
ok the first thing i can think of is that when you put the key in and turn it there should be 12 volts going to the system. now seeing that there is no chime and no audio tells me that perhaps your igniton module inside the steering column is defective. your turn signals have a module that is powered on when you turn the key as well. there should always be 12 volts to the ignition module. when you turn the key 12 volts goes to the ignition and all your accessories. like i mentioned before there should be a 10-12 pin wire harness that goes up your steering column. you have to check all the connections under the dash if they are good thios will tell you that the hot feedfrom the ignition is the problem and the module needs replacing... hope this clarifies things for you....pleqase rate thanks
Was this helpful?
Yes
No
Popular Solutions for Car Audio and Video
Questions and Unsolved Problems for Car Audio and Video
Answer
welooking pioneer car audio supplier to india
Answer
looking at buying a mercedes e200 kompressor automatic, what do you think?
Answer
Hello...I have a 2001 Mitsubishi Galant and I was wondering what the raio code is? The model number... (More)
Answer
The make of my JVC CD player is infact, KD-SX909R but the make didn't come up.
Answer
2005 Volvo V50, no radio volume, CD shows pause. Volume button does not work, cannot get CD mode out... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Audio and... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
